controller support.
Update #3269.
Update #3285.
Update #3285.
Update #3285.
system. Since all content of
makes no sense to keep it.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #2408.
Update #3285.
Update #3285.
Update #3285.
Update #3387.
Update #3285.
Update #3285.
Update #3285.
upgrade to that version.
Close #3387.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
* bsps/shared/cache
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3254.
EXTRA_DIST += foobar
in fragments.
Update #3254.
Update #3254.
Updates #3520.
Updates #3520.
Patch was not intended to be pushed yet.
Updates #3520.
Done:
arm
bfin
epiphany
i386
lm32
m32c
mips
moxie
nios2
or1k
powerpc
riscv
sh
sparc
sparc64
v850
To do:
m68k
Differences noted:
+ endfile was sometimes before startfile
+ endfile sometimes was hard-coded and did not have -qrtems version
+ Should -e XXX (e.g. entry point) be in linkcmds?
+ Should -u XXX (e.g. undefined symbols) be in linkcmds?
+ Typos: Odd spacing, "old_endfiles" typo, and *(old_endfiles) (not %)
+ nios2: Referenced crtnn.o not crtn.o (error)
Need to revisit:
+ m32c, moxie, sparc64 includes !nostdlib which is not used elsewhere
+ sh has -EL/-EB mapping. Why needed?
+ sparc64 didn't include crti.o/crtn.o but it is part of toolset
+ v850 uses something like this for link and end_file:
"%{qrtems: %(old_link)}"
This means that these are unnecessary. Try this on all.
+ mips uses old_link all the time also.
+ arm/tms750 adds -EB.
+ powerpc: Why do we have rtems_crt* and not use something from GCC?
Updates #3520.
Updates #3250.
maintain.
Update #3254.
BSP_PRESS_KEY_FOR_RESET=0
BSP_RESET_BOARD_AT_EXIT=1
BSP_PRINT_EXCEPTION_CONTEXT=1
Update #3239.
updates #2577.
For the eZKit533 BSP variant without this option sample executables
sizes were as follows:
75160 1628 9224 86012 14ffc ticker.exe
49156 1388 5964 56508 dcbc minimum.exe
475080 5708 22440 503228 7adbc fileio.exe
369432 12224 38436 420092 668fc pppd.exe
162344 2284 12136 176764 2b27c capture.exe
90168 1716 9296 101180 18b3c nsecs.exe
152840 2000 9828 164668 2833c paranoia.exe
74168 1628 9192 84988 14bfc base_sp.exe
76520 1656 13020 91196 1643c unlimited.exe
87976 1600 9172 98748 181bc hello.exe
222716 6116 16540 245372 3be7c loopback.exe
For the eZKit533 BSP variant with this option sample executables
68400 1590 9220 79210 1356a ticker.exe
28220 1265 5700 35185 8971 minimum.exe
458108 5670 22178 485956 76a44 fileio.exe
331040 8892 37588 377520 5c2b0 pppd.exe
151020 2214 12091 165325 285cd capture.exe
83172 1678 9304 94154 16fca nsecs.exe
143360 1958 9804 155122 25df2 paranoia.exe
65208 1586 9216 76010 128ea base_sp.exe
66952 1606 13032 81590 13eb6 unlimited.exe
78016 1538 9196 88750 15aae hello.exe
195396 2834 16368 214598 34646 loopback.exe
Update #2408.
Notepads where a feature of RTEMS' tasks that simply functioned in
the same way as POSIX keys or threaded local storage (TLS). They were
introduced well before per task variables, which are also deprecated,
and were barely used in favor of their POSIX alternatives.
In addition to their scarce usage, Notepads took up unnecessary memory.
For each task:
- 16 32-bit integers were allocated.
- A total of 64 bytes per task per thread.
This is especially critical in low memory and safety-critical applications.
They are also defined as uint32_t, and therefore are not guaranteed to
hold a pointer.
Lastly, they are not portable solutions for SMP and uniprocessor systems,
like POSIX keys and TLS.
updates #2493.
Update #2408.
Rename BSP-specific bsp_pretasking_hook() to bsp_predriver_hook().
Update #2408.
Update #2408.
do
echo $b
# echo $g
-i $b
done
