Fix typo.
closes 2345.
warning and clean up
not updated.
The TLS section symbols had wrong values in case of an empty TLS data
section and a nonempty TLS BSS section.
Conflicts:
* console/console-io.c: Regenerated for TLL6527M.
* include/tm27.h, startup/bspstart.c:
* Makefile.am: Do not use .rel files for libbsp pieces.
* console/console-io.c: Let eZKit533_BSP_poll_char return int.
* make/custom/eZKit533.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/eZKit533.cfg: Switch to compiling at O2.
* startup/bspstart.c: Add missing prototype.
* make/custom/eZKit533.cfg: New (relocated from /make/custom).
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* bsp_specs: Move -e start from *link to *startfile to avoid warning
for undefined entry symbol when linking relocatables with binutils
2.19.
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* include/bsp.h: Rely on clock driver to determine when we should use
fast idle.
* configure.ac: Add BFIN_ON_SKYEYE define to disable features not
supported on simulator.
* configure.ac: Make letting boot_card() handle work area allocation
mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to
* include/bsp.h: Remove unnecessary boilerplate comments.
* Makefile.am, startup/linkcmds: Use top level shared
bsp_get_work_area() implementation.
* startup/bspstart.c: Remove unnecessary includes of
rtems/libcsupport.h and rtems/libio.h.
* Makefile.am, configure.ac, startup/bspstart.c, startup/linkcmds:
Split out bsp_get_work_area() into its own file and user BSP
Framework to perform more initialization.
* Makefile.am, console/console-io.c, startup/bspstart.c: Update to use
shared libcpu version of code implemented as part of bf537Stamp
effort.
* include/bsp.h: Fix CVS Id.
