Notepads where a feature of RTEMS' tasks that simply functioned in
the same way as POSIX keys or threaded local storage (TLS). They were
introduced well before per task variables, which are also deprecated,
and were barely used in favor of their POSIX alternatives.
In addition to their scarce usage, Notepads took up unnecessary memory.
For each task:
- 16 32-bit integers were allocated.
- A total of 64 bytes per task per thread.
This is especially critical in low memory and safety-critical applications.
They are also defined as uint32_t, and therefore are not guaranteed to
hold a pointer.
Lastly, they are not portable solutions for SMP and uniprocessor systems,
like POSIX keys and TLS.
updates #2493.
Update #2408.
Rename BSP-specific bsp_pretasking_hook() to bsp_predriver_hook().
Update #2408.
Update #2408.
do
echo $b
# echo $g
-i $b
done
Fix typo.
closes 2345.
warning and clean up
not updated.
The TLS section symbols had wrong values in case of an empty TLS data
section and a nonempty TLS BSS section.
Conflicts:
* console/console-io.c: Regenerated for TLL6527M.
* include/tm27.h, startup/bspstart.c:
* Makefile.am: Do not use .rel files for libbsp pieces.
* console/console-io.c: Let eZKit533_BSP_poll_char return int.
* make/custom/eZKit533.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/eZKit533.cfg: Switch to compiling at O2.
* startup/bspstart.c: Add missing prototype.
* make/custom/eZKit533.cfg: New (relocated from /make/custom).
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* bsp_specs: Move -e start from *link to *startfile to avoid warning
for undefined entry symbol when linking relocatables with binutils
2.19.
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* include/bsp.h: Rely on clock driver to determine when we should use
fast idle.
* configure.ac: Add BFIN_ON_SKYEYE define to disable features not
supported on simulator.
* configure.ac: Make letting boot_card() handle work area allocation
mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to
* include/bsp.h: Remove unnecessary boilerplate comments.
