Update #3285.
* ChangeLog, start/start.S: Add HLT instruction on exit.
PR 1488/bsps
* start/start.S: Micromon on bf537 uses DMA for UART reception.
This prevents the UART driver in RTEMS from working (and also
causes received characters to be stored in a buffer that RTEMS
doesn't know about, so it's potentially dangerous, but in practice
the risk is small since an RTEMS app intended to be booted from
Micromon would normally be configured to leave the RAM Micromon
uses reserved). The attached patch corrects this by disabling
all DMA channels at startup.
* start/start.S: Correct call to boot_card to meet bfin abi by
clearing l0 - l3 and allocating some stack space.
* start/start.S: Update for boot_card command line change.
* ChangeLog, Makefile.am, README, bsp_specs, configure.ac,
preinstall.am, console/console.c, include/bsp.h,
network/networkconfig.c, start/start.S, startup/bspstart.c,
startup/linkcmds: New files.
