* | Cosmetics. | Ralf Corsepius | 2008-09-29 | 1 | -1/+0 |
* | 2008-09-29 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2008-09-28 | 1 | -0/+4 |
| | | | | * Makefile.am: Cleanup. | ||||
* | New. | Ralf Corsepius | 2008-09-28 | 2 | -38/+47 |
* | 2008-09-18 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-18 | 2 | -14/+4 |
| | | | | * include/bsp.h: Remove unnecessary boilerplate comments. | ||||
* | 2008-09-18 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-09-18 | 2 | -8/+6 |
| | | | | | * include/bsp.h: Eliminate definitions of BSP_LIBIO_MAX_FDS since this is NOT used anywhere. | ||||
* | Cleanup. | Ralf Corsepius | 2008-07-14 | 1 | -6/+0 |
* | 2007-12-11 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-12-11 | 2 | -4/+5 |
| | | | | | * include/bsp.h: Eliminate copies of the Configuration Table. Use the RTEMS provided accessor macros to obtain configuration fields. | ||||
* | 2007-12-04 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-12-04 | 2 | -9/+6 |
| | | | | | | * include/bsp.h: Move interrupt_stack_size field from CPU Table to Configuration Table. Eliminate CPU Table from all ports. Delete references to CPU Table in all forms. | ||||
* | 2007-04-12 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-04-12 | 2 | -14/+6 |
| | | | | * bsp_specs: Remove "*cpp:". Remove qrtems_debug. | ||||
* | 2007-03-10 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2007-03-10 | 2 | -11/+6 |
| | | | | | | PR 1227/bsps * include/bsp.h: Remove MAX_LONG_TEST_DURATION and MAX_SHORT_TEST_DURATION. They are obsolete and unused. | ||||
* | 2007-01-26 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-01-26 | 2 | -2/+6 |
| | | | | * Makefile.am: Use MKDIR_P instead of mkdir_p. | ||||
* | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-12-02 | 2 | -1/+5 |
| | | | | * configure.ac: New BUG-REPORT address. | ||||
* | 2006-11-15 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-11-15 | 2 | -1/+5 |
| | | | | * configure.ac: Use AC_CONFIG_HEADER instead of AM_CONFIG_HEADER. | ||||
* | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-17 | 2 | -2/+6 |
| | | | | * configure.ac: Require autoconf-2.60. Require automake-1.10. | ||||
* | 2005-01-02 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-03 | 2 | -1/+7 |
| | | | | * Makefile.am: Remove build-variant support. | ||||
* | 2004-10-20 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-10-20 | 2 | -14/+1 |
| | | | | * include/bsp.h: Remove tm27 stuff. | ||||
* | Preinstall tm27.h | Ralf Corsepius | 2004-10-20 | 1 | -0/+4 |
* | 2004-10-20 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-10-20 | 3 | -0/+38 |
| | | | | | * include/tm27.h: New. * Makefile.am: Add tm27.h | ||||
* | Fix typo in previous change. | Ralf Corsepius | 2004-09-24 | 1 | -1/+1 |
* | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-09-24 | 2 | -1/+5 |
| | | | | * configure.ac: Require automake > 1.9. | ||||
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-21 | 1 | -3/+3 |
* | 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-01 | 2 | -2/+7 |
| | | | | | * include/bsp.h: Include <rtems/clockdrv.h> instead of <clockdrv.h>. * include/bsp.h: Include <rtems/console.h> instead of <console.h>. | ||||
* | 2004-02-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-19 | 2 | -1/+34 |
| | | | | | * Makefile.am: Reflect changes to bsp.am. Preinstall dist_project_lib*. | ||||
* | 2004-02-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-02-14 | 2 | -1/+5 |
| | | | | * Makefile.am: Reflect changes to bsp.am. | ||||
* | Fixup .cvsignore | Ralf Corsepius | 2004-02-12 | 1 | -2/+0 |
* | 2004-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-21 | 2 | -0/+9 |
| | | | | * Makefile.am: Add PREINSTALL_DIRS. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 2 | -2/+6 |
| | | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59. | ||||
* | 2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-11 | 2 | -2/+6 |
| | | | | * Makefile.am: Misc cleanups and fixes. | ||||
* | 2003-10-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-10-22 | 2 | -1/+4 |
| | | | | * configure.ac: Remove RTEMS_CANONICAL_HOST. | ||||
* | 2003-10-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-10-20 | 2 | -1/+4 |
| | | | | * configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP. | ||||
* | 2003-09-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-09-29 | 4 | -28/+16 |
| | | | | | | | * Makefile.am: Merge-in include/Makefile.am. Reflect changes to bsp.am. * include/Makefile.am: Remove. * configure.ac: Reflect changes above. | ||||
* | 2003-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-04 | 2 | -1/+5 |
| | | | | * include/bsp.h: URL for license changed. | ||||
* | 2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-18 | 2 | -1/+5 |
| | | | | * Makefile.am: Reflect having moved aclocal/. | ||||
* | Fix broken ChangeLog entries. | Ralf Corsepius | 2003-08-18 | 1 | -2/+2 |
* | 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-16 | 3 | -3/+8 |
| | | | | | Makefile.am: Reflect having moved automake. include/Makefile.am: Reflect having moved automake. | ||||
* | Correcting to include PR numbers. | Joel Sherrill | 2003-08-14 | 1 | -0/+1 |
* | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-11 | 2 | -1/+5 |
| | | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address. | ||||
* | 2003-08-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-06 | 2 | -2/+5 |
| | | | | * bsp_specs: Remove -D__embedded__ -Asystem(embedded) from cpp. | ||||
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2003-03-11 | 2 | -1/+4 |
* | 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-02-11 | 2 | -1/+5 |
| | | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]). | ||||
| | | | | * configure.ac: AC_PREREQ(2.57). | ||||
* | 2002-12-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-06 | 2 | -1/+4 |
| | | | | * configure.ac: Remove RTEMS_CHECK_BSP_CACHE. | ||||
* | 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-10-21 | 2 | -3/+9 |
| | | | | | | * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache. | ||||
* | 2002-08-21 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-08-21 | 2 | -4/+8 |
| | | | | * bsp_specs: Added support for -nostdlibs. | ||||
* | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-28 | 4 | -4/+10 |
| | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. | ||||
* | 2001-12-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-01-04 | 2 | -1/+6 |
| | | | | | * bsp_specs: Replace -lrtemsall with -lrtemsbsp -lrtemscpu, replace -lrtemsall_g with -lrtemsbsp_g -lrtemscpu_g. | ||||
* | 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-10-12 | 1 | -0/+26 |
| | | | | | * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. | ||||
* | 2001-10-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-10-12 | 1 | -25/+0 |
| | | | | | | * .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. * configure.ac: New file, generated from configure.in by autoupdate. | ||||
* | 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-10-11 | 2 | -0/+7 |
* | 2001-09-27 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2001-09-28 | 2 | -1/+5 |
| | | | | * include/bsp.h: Renamed delay() to rtems_bsp_delay(). |
