* Makefile.am: Remove build-variant support.
* include/bsp.h: Remove tm27 stuff.
* include/tm27.h: New.
* Makefile.am: Add tm27.h
* Makefile.am: Reflect changes to bsp.am.
Preinstall dist_project_lib*.
* Makefile.am: Misc cleanups and fixes.
* configure.ac: Remove RTEMS_CANONICAL_HOST.
* configure.ac: Remove RTEMS_CHECK_CUSTOM_BSP.
* include/bsp.h: URL for license changed.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* configure.in: Remove.
* include/Makefile.am: fix path to shared/include/coverhd.h.
* include/.cvsignore: Add bspopts.h*, coverhd.h, stamp-h*.
something indicates this. Eventually this needs to be merged into
gcc.
that contains:
* Removes MKLIB
handling)
that contains:
regarded as bugs).
now works).
* removes libbsp/bare/wrapup
* Further cleanups
that converts nearly all of libbsp/sh to automake. Comments follow:
1. Almost full automake support for the libbsp/sh/ subdirectories
(exception libbsp/sh/gensh*/wrapup/*)
2. Fixes for libbsp/bare/*
3. Updates to libbsp/* configuration which supports old (autoconf/deep
configuration) and new (automake/flat/cascaded configuration) style
configuration of libbsp/<cpu>/*
