* Makefile.am: Reflect changes to bsp.am.
* Makefile.am: Misc cleanups and fixes.
that contains:
regarded as bugs).
now works).
* removes libbsp/bare/wrapup
* Further cleanups
which ontains all what was left over from the other patches (Primarily
minor configuration cleanups).
patch -p1 < rtems-rc-19991203-9.diff
./bootstrap
which adds automake support to libbsp/bare.
