* Makefile.am: Don't reference non-existing files.
* Makefile.am, configure.ac: runtest for this BSP obsoleted by
rtems-testing/sim-scripts support. Please use those scripts.
* tools/.cvsignore, tools/Makefile.am, tools/configure.ac,
tools/runtest.in: Removed.
* tools/configure.ac: Remove RTEMS_CANONICAL_TARGET_CPU.
Fix package name.
* include/bsp.h:
* tools/configure.ac: Require autoconf-2.68, automake-1.11.1.
* bsp_specs: Remove warning on __start not found.
* make/custom/avrtest.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/avrtest.cfg: New (relocated from /make/custom).
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* README: Included information about simulavrxx
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* start/start.S: copied gcrt1.S and macros.inc from avr-libc.
Change from call main to call boot_card for RTEMS.
* start/macros.inc: New file.
* startup/linkcmds: Correct to have 65K total RAM (mostly external) and
correct base address.
* include/bsp.h: Add BSP_SMALL_MEMORY.
* start/start.S: Update for boot_card command line change.
* Makefile.am: Rework.
* bsp_specs, start/start.S: Move -e start from *link to *startfile to
avoid warning for undefined entry symbol when linking relocatables
with binutils 2.19. Also rename entry from _init to _start to avoid
conflict with C++ constructor method name on other architectures.
* .cvsignore: New file.
* ChangeLog, Makefile.am, acinclude.m4, configure.ac: New files.
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac,
preinstall.am, console/console-io.c, include/.cvsignore,
include/bsp.h, start/start.S, startup/linkcmds, tools/.cvsignore,
tools/Makefile.am, tools/configure.ac, tools/runtest.in: New files.
