The file console-polled.h provides the prototypes for the three
required methods when implementing a single port polled console
driver. This paradigm is common on simulators and simple hardware.
+ Updated the BSPs Makefile.am to make console-polled.h available.
+ Regenerated the BSPs preinstall.sm.
+ Updated console support files to include <bsp/console-polled.h>.
+ Updated console support files to make printk() support method static.
The following BSPs do not have tick support so the tests fail:
arm1136jfs
arm1136js
arm7tdmi
arm920
armcortexa9 (does not run any more)
avrtest
h8sim
h8sxsim
m32csim
m32rsim
moxiesim
simsh1
simsh2
simsh4
v850e1sim
v850e2sim
v850e2v3sim
v850esim
v850essim
v850sim
This list was provided by Joel in the following post:
http://www.rtems.org/pipermail/rtems-devel/2014-April/006526.html
The TLS section symbols had wrong values in case of an empty TLS data
section and a nonempty TLS BSS section.
This is necessary to add tests that use the cache manager. For example
to get better estimates of worst-case timings.
Conflicts:
* Makefile.am: Don't reference non-existing files.
* Makefile.am, configure.ac: runtest for this BSP obsoleted by
rtems-testing/sim-scripts support. Please use those scripts.
* tools/.cvsignore, tools/Makefile.am, tools/configure.ac,
tools/runtest.in: Removed.
* tools/configure.ac: Remove RTEMS_CANONICAL_TARGET_CPU.
Fix package name.
* include/bsp.h:
* tools/configure.ac: Require autoconf-2.68, automake-1.11.1.
* bsp_specs: Remove warning on __start not found.
* make/custom/avrtest.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/avrtest.cfg: New (relocated from /make/custom).
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* README: Included information about simulavrxx
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* start/start.S: copied gcrt1.S and macros.inc from avr-libc.
Change from call main to call boot_card for RTEMS.
* start/macros.inc: New file.
* startup/linkcmds: Correct to have 65K total RAM (mostly external) and
correct base address.
* include/bsp.h: Add BSP_SMALL_MEMORY.
* start/start.S: Update for boot_card command line change.
* Makefile.am: Rework.
* bsp_specs, start/start.S: Move -e start from *link to *startfile to
avoid warning for undefined entry symbol when linking relocatables
with binutils 2.19. Also rename entry from _init to _start to avoid
conflict with C++ constructor method name on other architectures.
* .cvsignore: New file.
* ChangeLog, Makefile.am, acinclude.m4, configure.ac: New files.
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac,
preinstall.am, console/console-io.c, include/.cvsignore,
include/bsp.h, start/start.S, startup/linkcmds, tools/.cvsignore,
tools/Makefile.am, tools/configure.ac, tools/runtest.in: New files.
