path: root/c/src/lib/libbsp/avr (follow)
* Most bsp.h: Switch to LIBBSP_@CPU@_@BSP_FAMILY@_H for guardJoel Sherrill2015-07-161-2/+2
| | | | | | | | | | | | | | | | | This was done by the following script run from libbsp: find * -name bsp.h | xargs -e grep -l "#ifndef.*_BSP_H" | while read b do echo $b cpu=`echo $b | cut -d'/' -f1 | tr '[:lower:]' '[:upper:]' ` bsp=`echo $b | cut -d'/' -f2 | tr '[:lower:]' '[:upper:]' ` g="LIBBSP_${cpu}_${bsp}_BSP_H" # echo $g sed -e "s/ifndef _BSP_H/ifndef ${g}/" \ -e "s/define _BSP_H/define ${g}/" \ -i $b done
* avrtest-testsuite.tcfg: Add tests with data size issuesJoel Sherrill2015-03-221-0/+5
* avrtest: Disable jffs2 and mrfs testsJoel Sherrill2015-03-221-0/+2
* Update bug report URLSebastian Huber2014-12-052-2/+2
* bsps: Move extern "C" to not cover includesSebastian Huber2014-10-231-4/+4
| | | | Some includes may use C++ and this conflicts if surrounded extern "C".
* Add console-polled.h and update all BSPs that should use it.Joel Sherrill2014-10-103-3/+11
| | | | | | | | | | | The file console-polled.h provides the prototypes for the three required methods when implementing a single port polled console driver. This paradigm is common on simulators and simple hardware. + Updated the BSPs Makefile.am to make console-polled.h available. + Regenerated the BSPs preinstall.sm. + Updated console support files to include <bsp/console-polled.h>. + Updated console support files to make printk() support method static.
* Regenerate all preinstall.am files.Chris Johns2014-08-291-6/+6
| | | | | With this patch the preinstall.am files are in a set order and not dependent on now perl implements a hash.
* bsps: Do not build tests that require a tick interrupt.Chris Johns2014-05-281-0/+5
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | The following BSPs do not have tick support so the tests fail: arm1136jfs arm1136js arm7tdmi arm920 armcortexa9 (does not run any more) avrtest h8sim h8sxsim m32csim m32rsim moxiesim simsh1 simsh2 simsh4 v850e1sim v850e2sim v850e2v3sim v850esim v850essim v850sim This list was provided by Joel in the following post: http://www.rtems.org/pipermail/rtems-devel/2014-April/006526.html
* multiple BSPs: Remove BSP_SMALL_MEMORYJoel Sherrill2014-05-061-2/+0
* bsps: Fix TLS support in linker command filesSebastian Huber2014-04-221-1/+3
| | | | | The TLS section symbols had wrong values in case of an empty TLS data section and a nonempty TLS BSS section.
* avrtest/include/bsp.h: Remove rtems_bsp_delay()Joel Sherrill2014-03-211-17/+0
* Change all references of rtems.com to rtems.org.Chris Johns2014-03-212-2/+2
* bsps: Add empty cache managerSebastian Huber2014-02-241-0/+5
| | | | | This is necessary to add tests that use the cache manager. For example to get better estimates of worst-case timings.
* bsps: Thread-local storage (TLS) for linkcmdsSebastian Huber2014-02-041-2/+16
* RTEMS: Delete ChangeLog files.Gedare Bloom2013-03-082-108/+0
| | | | | | | | | This commit deletes all RTEMS ChangeLog files. These files have been abandoned since converting to git version control. The historical data may be recovered by checking out any commit before this one. Most of the contents of these ChangeLog files can also be found in the git log. Two external ChangeLog files, ChangeLog.slac and ChangeLog.zlib, remain.
* score: Add RTEMS_FATAL_SOURCE_EXITSebastian Huber2012-11-151-0/+1
| | | | | | | Include <bsp/default-initial-extension.h> in all BSPs. Call rtems_fatal() with RTEMS_FATAL_SOURCE_EXIT as source and the exit() status code as fatal code in every bsp_cleanup(). Move previous bsp_cleanup() code into bsp_fatal_extension().
* Revert "Add bspopts.h.in."Gedare Bloom2012-08-061-31/+0
| | | | | | | | | | | | This reverts commit daffa606cc4a45d93c1f0f4fe365fde0fda6acbb. Conflicts: c/src/lib/libbsp/arm/lpc24xx/include/bspopts.h.in c/src/lib/libbsp/powerpc/mpc55xxevb/include/bspopts.h.in c/src/lib/libbsp/powerpc/qoriq/include/bspopts.h.in Manually deleted conflicting files.
* Require automake-1.12.2.Ralf Corsépius2012-07-192-2/+2
* Require autoconf-2.69.Ralf Corsépius2012-07-192-2/+2
* Add bspopts.h.in.Ralf Corsépius2012-05-241-0/+31
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-116-15/+0
* Remove CVS-Ids.Ralf Corsépius2012-05-044-12/+0
* Remove all .cvsignore files.Joel Sherrill2012-02-013-21/+0
* 2011-06-20 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-06-202-2/+4
| | | | * Makefile.am: Don't reference non-existing files.
* 2011-06-11 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-06-117-289/+7
| | | | | | | * Makefile.am, configure.ac: runtest for this BSP obsoleted by rtems-testing/sim-scripts support. Please use those scripts. * tools/.cvsignore, tools/Makefile.am, tools/configure.ac, tools/runtest.in: Removed.
* 2011-02-25 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-252-3/+6
| | | | | * tools/configure.ac: Remove RTEMS_CANONICAL_TARGET_CPU. Fix package name.
* 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-112-1/+6
| | | | | * include/bsp.h: Use "__asm__" instead of "asm" for improved c99-compliance.
* 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-024-4/+12
| | | | * configure.ac: Require autoconf-2.68, automake-1.11.1.
* 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-022-2/+6
| | | | * tools/configure.ac: Require autoconf-2.68, automake-1.11.1.
* 2010-04-25 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill2010-04-252-1/+5
| | | | * bsp_specs: Remove warning on __start not found.
* Whitespace removal.Ralf Corsepius2009-11-284-4/+4
* 2009-10-21 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-212-3/+4
| | | | * make/custom/avrtest.cfg: Remove RTEMS_BSP_FAMILY.
* 2009-10-20 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-202-1/+5
| | | | * configure.ac: Don't add -ansi -fasm to CFLAGS.
* 2009-10-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-152-0/+24
| | | | * make/custom/avrtest.cfg: New (relocated from /make/custom).
* 2009-09-15 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-09-152-2/+5
| | | | * configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* 2009-07-23 Josh Switnicki <josh.switnicki@utoronto.ca>Joel Sherrill2009-07-232-1/+27
| | | | * README: Included information about simulavrxx
* 2009-07-16 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-07-162-1/+8
| | | | | | * configure.ac: Rename BSP_BOOTCARD_OPTIONS to RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs have the same options.
* 2009-07-03 Josh Switnicki <josh.switnicki@utoronto.ca>Joel Sherrill2009-07-063-50/+627
| | | | | | * start/start.S: copied gcrt1.S and macros.inc from avr-libc. Change from call main to call boot_card for RTEMS. * start/macros.inc: New file.
* 2009-05-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-05-082-2/+7
| | | | | * startup/linkcmds: Correct to have 65K total RAM (mostly external) and correct base address.
* 2009-05-04 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-05-042-0/+6
| | | | * include/bsp.h: Add BSP_SMALL_MEMORY.
* 2009-04-28 Chris Johns <chrisj@rtems.org>Chris Johns2009-04-282-0/+7
| | | | * start/start.S: Update for boot_card command line change.
* 2009-02-25 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-02-251-0/+4
| | | | * Makefile.am: Rework.
* 2008-12-04 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-12-043-6/+13
| | | | | | | * bsp_specs, start/start.S: Move -e start from *link to *startfile to avoid warning for undefined entry symbol when linking relocatables with binutils 2.19. Also rename entry from _init to _start to avoid conflict with C++ constructor method name on other architectures.
* 2008-11-20 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-11-202-0/+12
| | | | * .cvsignore: New file.
* 2008-11-20 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-11-204-0/+49
| | | | * ChangeLog, Makefile.am, acinclude.m4, configure.ac: New files.
* 2008-11-20 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-11-2016-0/+908
* .cvsignore, ChangeLog, Makefile.am, README, bsp_specs, configure.ac, preinstall.am, console/console-io.c, include/.cvsignore, include/bsp.h, start/start.S, startup/linkcmds, tools/.cvsignore, tools/Makefile.am, tools/configure.ac, tools/runtest.in: New files.
