2021-09-21 | build: Remove old build system | Sebastian Huber | 45 | -3300/+0 | |
Close #3250. Close #4081. | |||||
2021-04-26 | Makefile.am: Remove legacy networking files | Vijay Kumar Banerjee | 8 | -40/+0 | |
2021-03-30 | bsps/xilinx_zynq: Add Xilinx AXI SPI driver to autotools build | Jan Sommer | 2 | -0/+2 | |
Closes #4321 | |||||
2021-03-10 | bsps/xilinx_zynq: Add SPI driver to autotools build | Jan Sommer | 2 | -0/+6 | |
Closes #4320 | |||||
2021-03-02 | bsps/beagle: Adding QEP driver support to BeagleBoneBlack BSP | James Fitzsimons | 1 | -0/+6 | |
2021-02-26 | bsps: Add default rtems_get_target_hash() | Sebastian Huber | 21 | -0/+21 | |
Update #4267. | |||||
2020-12-23 | bsps: Use header file for GIC architecture support | Sebastian Huber | 6 | -6/+0 | |
This avoids a function call overhead in the interrupt dispatching. Update #4202. | |||||
2020-12-11 | bsp/xilinx_zynq: Enable support for 4kiB MMU pages | Jan Sommer | 1 | -0/+4 | |
- Disabled by default - Enable using ARM_MMU_USE_SMALL_PAGES option Close 4192. | |||||
2020-12-02 | bsps: Move ARM GICv2 driver to bsps/shared | Kinsey Moore | 6 | -6/+12 | |
This moves the ARM GICv2 driver to bsps/shared to be usable by AArch64 code. | |||||
2020-12-02 | bsps: Move zynq-uart to bsps/shared | Kinsey Moore | 2 | -4/+4 | |
This moves the zynq-uart driver from bsps/arm/shared to bsps/shared to accomodate use by AArch64 BSPs. | |||||
2020-11-20 | bsps/imx: Move imx-gpio to arm/shared | Christian Mauderer | 1 | -1/+1 | |
Update #4180 | |||||
2020-11-20 | imx: Move imx_iomux to arm/shared | Christian Mauderer | 1 | -1/+1 | |
2020-10-05 | bsps: Break out AArch32 portions of GPT driver | Kinsey Moore | 3 | -3/+6 | |
This breaks AArch32-specific portions of the ARM GPT driver into their own file so that the generic code can be moved for reuse by other architectures. | |||||
2020-10-05 | Move ARM PL011 UART driver | Kinsey Moore | 3 | -3/+3 | |
This UART driver is now needed for BSPs other than ARM. | |||||
2020-07-31 | bsp/imx: Add a GPIO driver | Christian Mauderer | 1 | -0/+3 | |
Update 3869 | |||||
2020-04-15 | bsp/imx: Add an extra ecspi clock. | Christian Mauderer | 1 | -0/+3 | |
Some imx chips or boards don't use the same frequency for ECSPI and IPG. Update #3869 | |||||
2020-03-19 | gdbarmsim: Remove | Joel Sherrill | 3 | -80/+0 | |
Closes #3611. | |||||
2020-02-12 | arm/xilinx-zynq: Split console driver files | Sebastian Huber | 2 | -0/+3 | |
This avoids to pull in via printk() the Termios support which pulls in the file system support. This fixes a spconfig02 test failure. | |||||
2020-01-07 | bsp/raspberrypi: Updated the console API. | G S Niteesh | 1 | -4/+2 | |
Replaces the legacy termios API with new termios API (#3034) Replaces the custom PL011 serial driver with RTEMS arm-pl011. Update #3034 | |||||
2020-01-07 | bsp/raspberrypi: Enable FDT support. | G S Niteesh | 2 | -0/+13 | |
This commit adds FDT support to the BSP. | |||||
2020-01-07 | bsp/raspberrypi: Fix size of work area. | Christian Mauderer | 1 | -4/+0 | |
The BSP tried to get the size of the SDRAM based on the revision code. Unfortunately the code had some bugs so that the default size has been used. Beneath that the MMU table hasn't been adapted. This patch queries the SDRAM size via a special VC Mailbox call instead. For the MMU adaption a simmilar method to the one in the imx BSP is used. | |||||
2019-12-05 | bsp/xen: Use BSP options for all linkcmds vars | Sebastian Huber | 1 | -9/+14 | |
Update #3818. | |||||
2019-12-05 | bsp/xen: Create BSP | Jeff Kubascik | 3 | -0/+109 | |
Create the Xen BSP for Xen on ARM. | |||||
2019-11-19 | bsp/imx7: Rename linker command file | Sebastian Huber | 1 | -1/+1 | |
This BSP family uses only one linker command file. Use the standard name. Update #3818. | |||||
2019-11-19 | bsp/altcycv_devkit: Rename linker command file | Sebastian Huber | 1 | -1/+1 | |
2019-11-15 | bsp/lpc32xx: Remove unused TESTS_USE_PRINTK | Sebastian Huber | 1 | -3/+0 | |
2019-11-15 | Remove BSP_SMALL_MEMORY BSP option | Sebastian Huber | 1 | -4/+0 | |
Use the test state configuration instead. Update #3818. | |||||
2019-11-14 | bsp/beagle: Rename linker command file | Sebastian Huber | 1 | -1/+0 | |
2019-11-14 | bsp/gumstix: Remove ON_SKYEYE Automake conditional | Sebastian Huber | 1 | -2/+0 | |
It is fine to build the drivers always. Update #3818. | |||||
2019-11-14 | arm/stm32f4: Fix typo | Sebastian Huber | 1 | -1/+1 | |
2019-10-31 | bsps/arm: Add support for small pages MMU | Sebastian Huber | 1 | -0/+2 | |
The small page MMU support reduces the granularity for memory settings through the MMU from 1MiB sections to 4KiB small pages. Enable it by default on the realview_pbx_a9_qemu BSP. | |||||
2019-10-28 | bsp/xilinx-zynqmp: Fix linkcmds config | Sebastian Huber | 1 | -1/+1 | |
Bug was introduced by commit 1e1afa3779e594e09387fba1812d3028fb00cd9e. | |||||
2019-10-23 | bsp/xilinx-zynq: Simplify linkcmds config | Sebastian Huber | 1 | -26/+3 | |
Use NULL-pointer protection also for Qemu variant. Do all calculations in the linker command file. This is a preparation for the new build system. | |||||
2019-10-23 | bsp/xilinx-zynq: Simplify configure.ac | Sebastian Huber | 1 | -24/+10 | |
2019-10-23 | bsp/xilinx-zynqmp: Simplify linkcmds config | Sebastian Huber | 1 | -6/+0 | |
2019-10-23 | bsp/xilinx-zynqmp: Simplify configure.ac | Sebastian Huber | 1 | -21/+9 | |
Use NULL-pointer protection also for Qemu variant. | |||||
2019-08-12 | arm/raspberry: Set the workspace based on the mailbox version. | Chris Johns | 1 | -4/+16 | |
- Update the linkcmd file to support configure settings - Set the workspace size based on the revision value | |||||
2019-07-31 | arm/beagle: Add libdebugger support. | Chris Johns | 1 | -0/+1 | |
- Port the jbang code from C++ to C to enable DBGEN. - Hook the libdebugger ARM backend support to return the base address of the debug register set. | |||||
2019-07-26 | bsps/arm: Move HYP to SVC change to start.S | Sebastian Huber | 1 | -3/+0 | |
This fixes the corruption of r3 by the call to bsp_start_arm_drop_hyp_mode(). Moving the code makes it easier to review changes in start.S. Close #3773. | |||||
2019-07-26 | bsps/arm: Move register init to start.S | Sebastian Huber | 1 | -1/+0 | |
This makes it easier to review changes in start.S. Update #3773. | |||||
2019-06-18 | atsam: Add ATSAM_POWER_WAIT_MODE | Sebastian Huber | 1 | -0/+1 | |
2019-05-08 | bsp/lpc24xx: Remove obsolete BSP optinons | Sebastian Huber | 1 | -9/+0 | |
Update #3725. | |||||
2019-04-12 | bsp/imx: CLOCK_DRIVER_USE_ONLY_BOOT_PROCESSOR | Sebastian Huber | 1 | -5/+0 | |
Remove this BSP option. | |||||
2019-04-11 | bsp/xilinx-zynqmp: Implement Ultra96 target | Jeff Kubascik | 3 | -98/+66 | |
Modifications to get xilinx-zynqmp BSP working on an Ultra96 board. Update #3682. | |||||
2019-04-11 | bsp/xilinx-zynqmp: Stub out Xilinx MPSoC BSP | Jeff Kubascik | 2 | -0/+228 | |
Source files were copied from xilinx-zynq. Update #3682. | |||||
2019-04-11 | bsp/zynq-uart: Move Zynq UART driver to shared directory | Jeff Kubascik | 1 | -1/+1 | |
This driver will be shared with the xilinx-zynqmp BSP. Update #3682. | |||||
2019-03-15 | bsp/lpc24xx: Convert I2C driver to Linux API | Sebastian Huber | 1 | -1/+0 | |
Change license to BSD-2-Clause. Close #3725. | |||||
2019-02-27 | bsp/altera-cyclone-v: Move header file | Sebastian Huber | 1 | -2/+0 | |
This gets rid of a special include path. | |||||
2019-02-27 | arm/beagle: SPI driver | Pierre-Louis Garnier | 1 | -0/+3 | |
2019-02-18 | bsp/altera-cyclone-v: Use FDT for clock frequency | Sebastian Huber | 1 | -3/+2 | |
