* irq/Makefile.am: Use .$(OBJEXT) instead of .o.
* startup/Makefile.am: Added -DARM_RDI_MONITOR.
* irq/irq_asm.S: ARM port works well enough to run all sptests,
tmtests, and ttcp. In addition to general cleanup, there
has been considerable optimization to interrupt disable/enable,
endian swapping, and context switching.
Add bsplib_DATA = $(PROJECT_RELEASE)/lib/start$(LIB_VARIANT).o
(Didn't make it into cvs at 2002-07-20 :( )
* start/Makefile.am: Remove leftover from eliminating PGM.
* irq_bsp_irq_asm.S: Update to reflect irq_asm modifications.
* irq/irq_asm.S: Significant rework in attempt to make interrupts
work. They appear to be very close to correct but not 100%.
* start/start.S: Added SWI_Handler.
* irq/bsp_irq_asm.S: Disable code to touch PIC.
* wrapup/Makefile.am: Add $(LIB) to all-local.
* startup/linkcmds: In support of gcc 3.1, added one of more
of the sections .jcr, .rodata*, .data.*, .gnu.linkonce.s2.*,
.gnu.linkonce.sb2.*, and .gnu.linkonce.s.*. Spacing corrections
and direction of segments to memory regions may also have been
addressed. This was a sweep across all BSPs.
* configure.ac: Update, remove code rott.
* comm/Makefile.am: Remove AUTOMAKE_OPTIONS.
* console/console-io.c: Include rtems/bspIo.h instead of bspIo.h.
* startup/exit.c: Include rtems/bspIo.h instead of bspIo.h.
* comm/console.c: Include rtems/bspIo.h instead of bspIo.h.
* irq/irq_init.c: Include rtems/bspIo.h instead of bspIo.h.
* configure.ac: Add RTEMS_BSPOPTS_*(ARM_RDP_MONITOR).
* startup/Makefile.am: Remove ARM_RDP_MONITOR, AM_CPPFLAGS.
* configure.ac: Add RTEMS_BPSOPTS_* for ARM_RDI_MONITOR.
* timer: New subdirectory.
* timer/Makefile.am: New file.
* timer/.cvsignore: New file.
* Makefile.am: Modified to reflect above.
* configure.ac: Ditto.
* wrapup/Makefile.am: Ditto.
* include/bsp.h: Stubs to let tm27 compile and link.
* console/console-io.c: Fixed typo.
* configure.in: Remove.
* acinclude.m4: New file.
* irq/Makefile.am: Use 'PREINSTALL_FILES ='.
* comm/Makefile.am: Use 'PREINSTALL_FILES ='.
* comm/Makefile.am: Use *_HEADERS instead of *H_FILES.
* configure.in: remove shared/io/Makefile.
* configure.in: Add include/bspopts.h.
* console/Makefile.am: Use *_HEADERS instead of *H_FILES.
* irq/Makefile.am: Use *_HEADER instead of *H_FILES.
* include/.cvsignore: Add bspopts.h*, coverhd.h, stamp-h*
* include/Makefile.am: Add bspopts.h, Use *_HEADER instead of *H_FILES.
* include/bsp.h: Add bspopts.h.
* configure.in: Reworked for Canadian Cross support.
* config.guess, config.sub: Update from subversions.gnu.org.
* README.cdn-X: New file.
* tools/Makefile.am: Remove build, tools from SUBDIRS.
* include/bsp.h: Added closing brace for extern C.
* console/console-io.c: Added console_initialize_hardware().
* clock: New directory with stub clock driver.
* clock/.cvsignore, clock/Makefile.am, clock/clockdrv.c: New files.
* Makefile.am, configure.in, wrapup/Makefile.am: Modified
to reflect above.
* startup/bspstart.c: Removed call of console_reserve_resources().
* wrapup/Makefile.am: Corrected typo so BSP components are picked up.
* comm/console.c: Added casts to eliminate warnings.
* comm/console.c (console_reserve_resources): Removed.
* startup/bspstart.c: Removed unused variables ramSpace and _end.
Added prototype for initialize_monitor_handles().
* startup/syscalls.c: Added casts and removed unused variables to
eliminate warnings.
