path: root/c/src/lib/libbsp/arm (follow)
* 2003-09-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-292-2/+5
| | | | | * Makefile.am: Remove refs to non-existing files include/bspio.h and include/uart.h.
* 2003-09-29 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-2916-114/+84
| | | | | | | * Makefile.am: Merge-in include/Makefile.am. Reflect changes to bsp.am. * include/Makefile.am: Remove. * configure.ac: Reflect changes above.
* 2003-09-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-188-32/+16
| | | | * bsp_specs: Remove *lib:.
* 2003-09-15 Jay Monkman <jtm@smoothsmoothie.com>Jennifer Averett2003-09-152-6/+5
| | | | | PR 480/bsps * shared/irq/irq_asm.S: Remove duplicate code.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-044-3/+8
| | | | | * console/console-io.c, include/bsp.h, startup/bspstart.c: URL for license changed.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-0420-18/+30
| | | | | | * include/bsp.h, include/registers.h, irq/bsp_irq_asm.S, irq/bsp_irq_init.c, irq/irq.c, irq/irq.h, start/start.S, startup/bspstart.c, startup/exit.c: URL for license changed.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-046-5/+10
| | | | | * comm/console.c, comm/uart.c, comm/uart.h, irq/irq_asm.S, irq/irq_init.c: URL for license changed.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-0414-13/+20
| | | | | | | * clock/clockdrv.c, console/uart.c, include/bsp.h, include/ep7312.h, irq/bsp_irq_asm.S, irq/bsp_irq_init.c, irq/irq.c, irq/irq.h, start/start.S, startup/bspstart.c, startup/exit.c, startup/linkcmds, timer/timer.c: URL for license changed.
* 2003-08-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-1810-5/+25
| | | | * Makefile.am: Reflect having moved aclocal/.
* Fix broken ChangeLog entries.Ralf Corsepius2003-08-186-40/+40
* 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-162-2/+6
| | | | Makefile.am: Reflect having moved automake.
* 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-169-21/+32
| | | | | | | | | | | Makefile.am: Reflect having moved automake. clock/Makefile.am: Reflect having moved automake. console/Makefile.am: Reflect having moved automake. include/Makefile.am: Reflect having moved automake. start/Makefile.am: Reflect having moved automake. startup/Makefile.am: Reflect having moved automake. timer/Makefile.am: Reflect having moved automake. wrapup/Makefile.am: Reflect having moved automake.
* 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-1620-48/+72
| | | | | | | | | | | | Makefile.am: Reflect having moved automake. clock/Makefile.am: Reflect having moved automake. console/Makefile.am: Reflect having moved automake. include/Makefile.am: Reflect having moved automake. irq/Makefile.am: Reflect having moved automake. start/Makefile.am: Reflect having moved automake. startup/Makefile.am: Reflect having moved automake. timer/Makefile.am: Reflect having moved automake. wrapup/Makefile.am: Reflect having moved automake.
* 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-164-4/+10
| | | | | | Makefile.am: Reflect having moved automake. comm/Makefile.am: Reflect having moved automake. irq/Makefile.am: Reflect having moved automake.
* 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-1611-27/+40
| | | | | | | | | | | | | Makefile.am: Reflect having moved automake. clock/Makefile.am: Reflect having moved automake. console/Makefile.am: Reflect having moved automake. include/Makefile.am: Reflect having moved automake. irq/Makefile.am: Reflect having moved automake. network/Makefile.am: Reflect having moved automake. start/Makefile.am: Reflect having moved automake. startup/Makefile.am: Reflect having moved automake. timer/Makefile.am: Reflect having moved automake. wrapup/Makefile.am: Reflect having moved automake.
* Correcting to include PR numbers.Joel Sherrill2003-08-144-0/+8
* 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-112-2/+4
| | | | * startup/Makefile.am: Remove USE_INIT_FINI.
* 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-1110-5/+25
| | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address.
* 2003-08-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-068-12/+20
| | | | | * bsp_specs: Remove -D__embedded__ -Asystem(embedded) from cpp. Remove cpp, old_cpp (now unused).
* 2003-08-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-066-3/+15
| | | | * bsp_specs: Remove -DUSE_ENHANCED_INTR_API.
* Merger from rtems-4-6-branch.Ralf Corsepius2003-03-1110-5/+20
* 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-02-1110-5/+25
| | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]).
| | | | * configure.ac: AC_PREREQ(2.57).
* 2003-01-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-01-208-0/+60
| | | | * startup/linkcmds: Add FreeBSD SYSCTL() sections for networking.
* 2002-12-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-138-7/+10
| | | | | | | | | | * clock/Makefile.am: Don't include @RTEMS_BSP@.cfg. * console/Makefile.am: Don't include @RTEMS_BSP@.cfg. * irq/Makefile.am: Don't include @RTEMS_BSP@.cfg. * network/Makefile.am: Don't include @RTEMS_BSP@.cfg. * start/Makefile.am: Don't include @RTEMS_BSP@.cfg. * startup/Makefile.am: Don't include @RTEMS_BSP@.cfg. * timer/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* 2002-12-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-136-5/+8
| | | | | | | | * clock/Makefile.am: Don't include @RTEMS_BSP@.cfg. * console/Makefile.am: Don't include @RTEMS_BSP@.cfg. * start/Makefile.am: Don't include @RTEMS_BSP@.cfg. * startup/Makefile.am: Don't include @RTEMS_BSP@.cfg. * timer/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* 2002-12-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-1314-12/+18
| | | | | | | | | * clock/Makefile.am: Don't include @RTEMS_BSP@.cfg. * console/Makefile.am: Don't include @RTEMS_BSP@.cfg. * irq/Makefile.am: Don't include @RTEMS_BSP@.cfg. * start/Makefile.am: Don't include @RTEMS_BSP@.cfg. * startup/Makefile.am: Don't include @RTEMS_BSP@.cfg. * timer/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* 2002-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-128-4/+28
| | | | * start/Makefile.am: Use install-data-local to install startfile.
* 2002-12-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-108-4/+16
| | | | * wrapup/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* 2002-12-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-062-1/+4
| | | | * configure.ac: Remove RTEMS_CHECK_BSP_CACHE.
* 2002-12-02 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-12-024-1/+12
| | | | | * configure.ac, network/Makefile.am: Don't build if networking disabled. * startup/linkcmds: Add sections to remove warnings.
* 2002-11-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-11-182-1/+5
| | | | * network/network.c: Fix inconsistency in prototyping.
* 2002-11-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-11-132-1/+5
| | | | * network/network.c: Removed warning per Jay's suggestion.
* 2002-11-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-11-133-12/+24
| | | | | * include/.cvsignore: Corrected. * network/.cvsignore: New file.
* 2002-11-13 Jay Monkman <jtm@smoothsmoothie.com>Joel Sherrill2002-11-132-0/+6
| | | | * acinclude.m4: Added edb7312.
* 2002-11-13 Jay Monkman <jtm@smoothsmoothie.com>Joel Sherrill2002-11-1338-0/+2821
| | | | | | | | | | | | | | | * New BSP. * .cvsignore, ChangeLog, Makefile.am, bsp_specs, configure.ac, README, times, clock/.cvsignore, clock/Makefile.am, clock/clockdrv.c, console/.cvsignore, console/Makefile.am, console/uart.c, include/.cvsignore, include/Makefile.am, include/bsp.h, include/ep7312.h, irq/.cvsignore, irq/Makefile.am, irq/bsp_irq_asm.S, irq/bsp_irq_init.c, irq/irq.c, irq/irq.h, network/Makefile.am, network/network.c, start/.cvsignore, start/Makefile.am, start/start.S, startup/.cvsignore, startup/Makefile.am, startup/bspstart.c, startup/exit.c, startup/linkcmds, timer/.cvsignore, timer/Makefile.am, timer/timer.c, wrapup/.cvsignore, wrapup/Makefile.am: New file.
* 2002-11-13 Jay Monkman <jtm@smoothsmoothie.com>Joel Sherrill2002-11-133-1/+11
| | | | | * irq/irq_asm.S, irq/irq_init.c: Fixes a bug with handling the situation where we are processing an IRQ, and we receive an FIQ.
* 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-218-12/+36
| | | | | | * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache.
* 2002-10-04 Jay Monkman <jtm@smoothsmoothie.com>Joel Sherrill2002-10-042-0/+10
| | | | * irq/irq_asm.S: Add FIQ support.
* 2002-08-21 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-216-12/+24
| | | | * bsp_specs: Added support for -nostdlibs.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-1116-28/+48
| | | | | | | | | | * clock/Makefile.am: Use .$(OBJEXT) instead of .o. * console/Makefile.am: Use .$(OBJEXT) instead of .o. * irq/Makefile.am: Use .$(OBJEXT) instead of .o. * start/Makefile.am: Use .$(OBJEXT) instead of .o. * startup/Makefile.am: Use .$(OBJEXT) instead of .o. * timer/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-117-13/+22
| | | | | | | | | * clock/Makefile.am: Use .$(OBJEXT) instead of .o. * console/Makefile.am: Use .$(OBJEXT) instead of .o. * start/Makefile.am: Use .$(OBJEXT) instead of .o. * startup/Makefile.am: Use .$(OBJEXT) instead of .o. * timer/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-07-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-302-0/+12
| | | | * startup/Makefile.am: Added -DARM_RDI_MONITOR.
* 2002-07-30 Jay Monkman <jtm@smoothsmoothie.com>Joel Sherrill2002-07-302-17/+20
| | | | | | | * irq/irq_asm.S: ARM port works well enough to run all sptests, tmtests, and ttcp. In addition to general cleanup, there has been considerable optimization to interrupt disable/enable, endian swapping, and context switching.
* 2002-07-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-212-0/+8
| | | | | | * start/Makefile.am: Add bsplib_DATA = $(PROJECT_RELEASE)/lib/start$(LIB_VARIANT).o (Didn't make it into cvs at 2002-07-20 :( )
* 2002-07-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-212-3/+4
| | | | * start/Makefile.am: Remove leftover from eliminating PGM.
* 2002-07-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-206-13/+26
| | | | | * start/Makefile.am: Eliminate PGM. Add bsplib_DATA = $(PROJECT_RELEASE)/lib/start$(LIB_VARIANT).o.
* 2002-07-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-196-0/+18
| | | | * startup/Makefile.am: Add bsplib_DATA = linkcmds.
* 2002-07-17 Jay Monkman <jtm@smoothsmoothie.com>Joel Sherrill2002-07-172-3/+8
| | | | * irq_bsp_irq_asm.S: Update to reflect irq_asm modifications.
* 2002-07-17 Jay Monkman <jtm@smoothsmoothie.com>Joel Sherrill2002-07-172-89/+154
| | | | | * irq/irq_asm.S: Significant rework in attempt to make interrupts work. They appear to be very close to correct but not 100%.
