* | bsp/lpc24xx: More flexible region configuration | Sebastian Huber | 2012-06-15 | 3 | -46/+67 |
* | bsp/lpc24xx: Fix timing for M29W320E70 | Sebastian Huber | 2012-06-15 | 1 | -2/+2 |
* | bsp/lpc24xx: Add lpc24xx_module_is_enabled() | Sebastian Huber | 2012-06-15 | 2 | -0/+26 |
* | bsp/lpc24xx: Ethernet support for EA LPC1788 board | Sebastian Huber | 2012-06-15 | 1 | -1/+1 |
* | bsp/lpc24xx: Ethernet support for LPC17XX | Sebastian Huber | 2012-06-15 | 1 | -9/+26 |
* | bsp/lpc24xx: Use external RAM | Sebastian Huber | 2012-06-15 | 1 | -4/+4 |
* | bsp/lpc24xx: Use RAS and CAS of 2 for IS42S32800B | Sebastian Huber | 2012-06-15 | 1 | -18/+2 |
* | bsp/lpc24xx: Simplify EMCDLYCTL handling | Sebastian Huber | 2012-06-15 | 1 | -13/+24 |
* | bsp/lpc24xx: Simplify EMC configuration | Sebastian Huber | 2012-06-15 | 3 | -137/+129 |
* | bsp/lpc24xx: New BSP variants (PLX800 on LPC1778) | Sebastian Huber | 2012-06-15 | 7 | -13/+85 |
* | bsps/arm: Rename linkcmds.armv7 to linkcmds.armv7m | Sebastian Huber | 2012-06-15 | 7 | -8/+8 |
* | libchip: Add support for NS16550 with FDR | Sebastian Huber | 2012-06-15 | 1 | -4/+4 |
* | sapi: Add nanoseconds_per_tick to configuration | Sebastian Huber | 2012-06-14 | 1 | -1/+1 |
| | | | | | | Add nanoseconds_per_tick to rtems_configuration_table. This value will be derived from the microseconds_per_tick value. This avoids some calculations at run-time. | ||||
* | bsps: Replace NIRVANA region | Sebastian Huber | 2012-06-12 | 27 | -28/+13 |
| | | | | | Replace the "NIRVANA" region with the more verbose "UNEXPECTED_SECTIONS" region. Move the region definition into the "linkcmds.base" files. | ||||
* | Fix C files which had two semi-colons at EOL | Joel Sherrill | 2012-05-31 | 2 | -3/+3 |
* | Add bspopts.h.in. | Ralf Corsépius | 2012-05-24 | 14 | -0/+693 |
* | Remove CVS Id Strings (manual edits after script) | Joel Sherrill | 2012-05-11 | 2 | -16/+13 |
| | | | | | | These modifications were required by hand after running the script. In some cases, the file names did not match patterns. In others, the format of the file did not match any common patterns. | ||||
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 207 | -443/+0 |
* | Miscellaneous - Clean up file headers so patterns followed | Joel Sherrill | 2012-05-11 | 2 | -9/+6 |
| | | | | XXX | ||||
* | nds - Clock driver compiles again | Joel Sherrill | 2012-05-10 | 1 | -12/+17 |
* | nds/libnds - Fix missing prototype warning and formatting | Joel Sherrill | 2012-05-10 | 1 | -6/+9 |
* | Revert: Remove CVS Ids | Joel Sherrill | 2012-05-07 | 1 | -0/+3 |
| | | | | | See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | ||||
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 20 | -68/+0 |
* | nds/linkcmds - Remove execute permission | Joel Sherrill | 2012-05-03 | 1 | -0/+0 |
* | General - Remove extraneous blank line in license message | Joel Sherrill | 2012-05-03 | 33 | -21/+0 |
| | | | | | | | | | | | | | Many files had an extra blank line in the license text found in the file header. This patch removes that line. * The license and distribution terms for this file may be * found in the file LICENSE in this distribution or at * * http://www.rtems.com/license/LICENSE. The script that did this also turned off execute permission when it was turned on incorrectly. | ||||
* | smdk2410 - Remove odd $Id$ | Joel Sherrill | 2012-05-02 | 1 | -2/+0 |
* | gp32 - Remove odd $Id$ | Joel Sherrill | 2012-05-02 | 1 | -3/+0 |
* | bsps/stackalloc: Use stack section symbols | Sebastian Huber | 2012-04-24 | 3 | -25/+7 |
* | bsp/lpc24xx: Fix define name | Sebastian Huber | 2012-04-23 | 1 | -1/+1 |
* | bsps/arm: Make the Clock_isr() static again | Sebastian Huber | 2012-04-20 | 1 | -1/+1 |
* | bsps/arm: Remove superfluous include | Sebastian Huber | 2012-04-20 | 1 | -1/+0 |
* | lpc shared: Clock driver clean up and ISR Handler Prototype Correction. | Joel Sherrill | 2012-04-19 | 1 | -1/+1 |
* | armv7m shared: Clock driver clean up and ISR Handler Prototype Correction. | Joel Sherrill | 2012-04-19 | 1 | -1/+2 |
* | nds: Clock driver clean up and ISR Handler Prototype Correction. | Joel Sherrill | 2012-04-19 | 1 | -15/+8 |
* | gba: Clock driver clean up and ISR Handler Prototype Correction. | Joel Sherrill | 2012-04-19 | 1 | -32/+25 |
* | edb7312: Clock driver clean up and ISR Handler Prototype Correction. | Joel Sherrill | 2012-04-19 | 1 | -19/+14 |
* | bsp/stm32f4: API changes | Sebastian Huber | 2012-04-15 | 9 | -83/+174 |
* | bsp/stm32f4: Add IO and RCC | Sebastian Huber | 2012-04-12 | 9 | -55/+487 |
* | bsp/stm32f4: New BSP | Sebastian Huber | 2012-04-07 | 17 | -0/+1085 |
* | bsps/arm: Add BSP_ARMV7M_SYSTICK_PRIORITY | Sebastian Huber | 2012-04-07 | 3 | -5/+6 |
* | bsps/arm: Add BSP_ARMV7M_IRQ_PRIORITY_DEFAULT | Sebastian Huber | 2012-04-07 | 3 | -2/+6 |
* | bsps: Update due to API changes | Sebastian Huber | 2012-04-07 | 1 | -2/+2 |
* | bsp/lm3s69xx: Reflect new Qemu patch | Sebastian Huber | 2012-03-24 | 1 | -6/+1 |
* | bsps: Shared ARMv7-M interrupt support | Sebastian Huber | 2012-03-24 | 11 | -129/+184 |
* | bsps: Add shared default IRQ handler | Sebastian Huber | 2012-03-24 | 16 | -83/+69 |
* | bsp/lm3s69xx: Format | Sebastian Huber | 2012-03-24 | 2 | -58/+52 |
* | bsp/lm3s69xx: Use shared timer stub driver | Sebastian Huber | 2012-03-24 | 2 | -36/+1 |
* | bsp/lm3s69xx: Use shared start.S | Sebastian Huber | 2012-03-24 | 3 | -132/+12 |
* | bsps: Shared ARMv7-M clock driver | Sebastian Huber | 2012-03-24 | 5 | -14/+47 |
* | bsp/lm3s69xx: New Qemu patch | Sebastian Huber | 2012-03-24 | 1 | -0/+29 |
