* | bsp/raspberrypi: New BSP | Alan Cudmore | 2013-03-24 | 21 | -0/+1532 |
* | bsps: Support DWARF extension | Sebastian Huber | 2013-03-18 | 2 | -0/+4 |
* | bsp/edb7312: Improve output char | Sebastian Huber | 2013-03-14 | 1 | -11/+20 |
| | | | | | The output char function used by printk() is now independent of the console driver initialization. | ||||
* | bsp/edb7312: Fix warnings | Sebastian Huber | 2013-03-14 | 1 | -8/+0 |
* | RTEMS: Delete ChangeLog files. | Gedare Bloom | 2013-03-08 | 15 | -4683/+0 |
| | | | | | | | | | This commit deletes all RTEMS ChangeLog files. These files have been abandoned since converting to git version control. The historical data may be recovered by checking out any commit before this one. Most of the contents of these ChangeLog files can also be found in the git log. Two external ChangeLog files, ChangeLog.slac and ChangeLog.zlib, remain. | ||||
* | bsp/lpc32xx: Add BSP_USB_OTG_TRANSCEIVER_VBUS | Sebastian Huber | 2013-02-12 | 1 | -0/+3 |
* | bsp/lpc24xx: Move UART probes to separate files | Sebastian Huber | 2013-02-11 | 6 | -53/+130 |
* | libchip/serial: Add const qualifier | Sebastian Huber | 2013-02-11 | 12 | -15/+15 |
* | bsp/lpc32xx: Bypass the IrDA modem for UART6 | Sebastian Huber | 2013-01-11 | 1 | -3/+6 |
* | bsps/arm: Fix LPC Ethernet driver initialization | Sebastian Huber | 2013-01-09 | 1 | -0/+3 |
* | arm/smdk2410: Update to include bspidle.c | Joel Sherrill | 2013-01-08 | 1 | -1/+1 |
| | | | | | This BSP shares code with the gp32 and needed to include the new bspidle.c file. | ||||
* | arm/gp32: Correct compilation error in BSP Idle Thread | Joel Sherrill | 2013-01-08 | 4 | -24/+38 |
| | | | | | | | Split BSP Idle Thread into separate file to follow convention used on other BSPs. Slight reformatting of file header comment block. | ||||
* | bsp/lpc24xx: Declare conditionally | Sebastian Huber | 2013-01-07 | 1 | -0/+4 |
* | bsp/lpc32xx: System reset after fatal conditions | Sebastian Huber | 2013-01-07 | 1 | -1/+1 |
* | bsp/lpc24xx: System reset after fatal conditions | Sebastian Huber | 2013-01-07 | 1 | -1/+1 |
* | bsp/lpc24xx: Request system reset for LPC17XX | Sebastian Huber | 2013-01-07 | 1 | -4/+6 |
* | bsp/lpc24xx: Add WWDT module defines | Sebastian Huber | 2013-01-07 | 1 | -1/+21 |
* | arm: Add and use _ARMV7M_Exception_default() | Sebastian Huber | 2013-01-07 | 1 | -15/+16 |
* | arm: Rename inline functions | Sebastian Huber | 2013-01-07 | 2 | -4/+4 |
| | | | | | Rename arm_status_irq_enable() to _ARMV4_Status_irq_enable() and arm_status_restore() to _ARMV4_Status_restore(). | ||||
* | arm: Move inline functions | Sebastian Huber | 2013-01-07 | 1 | -0/+2 |
* | arm: Add and use default exception handler | Sebastian Huber | 2013-01-07 | 1 | -15/+15 |
| | | | | | | | | Add and use _ARMV4_Exception_undef_default(), _ARMV4_Exception_swi_default(), _ARMV4_Exception_data_abort_default(), _ARMV4_Exception_pref_abort_default(), _ARMV4_Exception_reserved_default(), _ARMV4_Exception_irq_default(), and _ARMV4_Exception_fiq_default(). | ||||
* | arm: Rename arm_exc_interrupt() | Sebastian Huber | 2013-01-07 | 4 | -4/+4 |
| | | | | Rename arm_exc_interrupt() to _ARMV4_Exception_interrupt(). | ||||
* | arm: Move prototypes to new file | Sebastian Huber | 2013-01-07 | 3 | -0/+5 |
| | | | | | | Move bsp_interrupt_dispatch() and arm_exc_interrupt() prototypes to new file <rtems/score/armv4.h> since they have nothing to do with the CPU port. | ||||
* | bsps/arm: Move promiscuous mode setting | Sebastian Huber | 2012-12-18 | 1 | -2/+3 |
* | bsps/arm: Add PHY up/down | Sebastian Huber | 2012-12-18 | 1 | -53/+211 |
| | | | | | | | | | | | | | All PHYs will be set to power up/down state with the BMCR[BMCR_PDOWN] setting. The KSZ80X1RNL will use the energy detect power down (EDPD) mode with PLL automatically turned in the up state. It will use the slow oscillator mode in the down state. To prevent system bus lock-ups the PHY is set to the up state before Ethernet module initialization. In case of a communication failure with the PHY or weird PHY identifiers the initialization will be aborted. | ||||
* | bsps/arm: Add PHY timeout detection | Sebastian Huber | 2012-12-18 | 1 | -9/+20 |
* | bsps/arm: Add interface down support | Sebastian Huber | 2012-12-18 | 3 | -43/+105 |
* | bsps/arm: Prepare for interface down support | Sebastian Huber | 2012-12-18 | 1 | -78/+83 |
* | bsps/arm: Use assert() instead of status macros | Sebastian Huber | 2012-12-18 | 1 | -33/+9 |
* | bsps/arm: Remove superfluous attributes | Sebastian Huber | 2012-12-18 | 1 | -3/+3 |
* | bsps/arm: Avoid mbuf migration in LPC ethernet | Sebastian Huber | 2012-12-18 | 1 | -56/+30 |
| | | | | | | The receive task will only hand over a mbuf if it gets a new one immediately. This avoids mbuf migration out of the receive task in case of overload. | ||||
* | bsp/lpc32xx: Add UART_CLKMODE settings | Sebastian Huber | 2012-12-18 | 2 | -0/+4 |
* | bsp/lpc32xx: Configure U4_TX pin for UART 4 | Sebastian Huber | 2012-12-18 | 1 | -0/+8 |
* | bsp/lpc32xx: Fix function prototype | Sebastian Huber | 2012-12-18 | 1 | -2/+2 |
* | bsp/lpc32xx: Add idle thread body | Sebastian Huber | 2012-12-18 | 3 | -0/+39 |
* | bsp/lpc32xx: Fix console baud configuration | Sebastian Huber | 2012-12-13 | 3 | -48/+64 |
* | bsp/gdbarmsim: Do not call bsp_cleanup() | Sebastian Huber | 2012-12-07 | 1 | -2/+0 |
* | bsp/csb637: Fix memory map | Sebastian Huber | 2012-12-03 | 1 | -2/+2 |
* | bsp/csb337: Fix memory map | Sebastian Huber | 2012-12-03 | 1 | -2/+2 |
* | bsps: Interrupt initialization error is fatal | Sebastian Huber | 2012-11-15 | 11 | -33/+11 |
* | score: Add RTEMS_FATAL_SOURCE_EXIT | Sebastian Huber | 2012-11-15 | 14 | -25/+41 |
| | | | | | | | Include <bsp/default-initial-extension.h> in all BSPs. Call rtems_fatal() with RTEMS_FATAL_SOURCE_EXIT as source and the exit() status code as fatal code in every bsp_cleanup(). Move previous bsp_cleanup() code into bsp_fatal_extension(). | ||||
* | bsps: Include <bspopts.h> in <bsp.h> | Sebastian Huber | 2012-11-14 | 1 | -0/+2 |
* | sapi: Delete duplicate declarations | Sebastian Huber | 2012-11-07 | 1 | -2/+0 |
* | bsp/nds: Do not change configuration | Sebastian Huber | 2012-11-07 | 1 | -3/+0 |
* | libblock: Block device transfer request API change | Sebastian Huber | 2012-11-02 | 1 | -2/+2 |
| | | | | | | | | | | | | | | Add and use rtems_blkdev_request_done(). Block device transfer requests must signal the completion status now with rtems_blkdev_request_done(). The return value of the block device IO control will be ignored for transfer requests. The first parameter of rtems_blkdev_request_cb is now the transfer request structure. Renamed rtems_blkdev_request::req_done to rtems_blkdev_request::done to break third party drivers at compile time, otherwise this API change would result in runtime errors. | ||||
* | libnetworking: Use system events | Sebastian Huber | 2012-11-02 | 5 | -16/+16 |
| | | | | | | | Add reserved system events RTEMS_EVENT_SYSTEM_NETWORK_SBWAIT and RTEMS_EVENT_SYSTEM_NETWORK_SOSLEEP. Add and use rtems_bsdnet_event_send(). | ||||
* | score: Work area initialization API change | Sebastian Huber | 2012-10-25 | 1 | -15/+5 |
| | | | | | | | | | | | | The work areas (RTEMS work space and C program heap) will be initialized now in a separate step and are no longer part of rtems_initialize_data_structures(). Initialization is performed with tables of Heap_Area entries. This allows usage of scattered memory areas present on various small scale micro-controllers. The sbrk() support API changes also. The bsp_sbrk_init() must now deal with a minimum size for the first memory chunk to take the configured work space size into account. | ||||
* | bsps: Remove unused bsp_libc_init() prototype | Sebastian Huber | 2012-10-15 | 1 | -1/+0 |
* | bsps/arm: Add BSP_USB_OTG_TRANSCEIVER_I2C_ADDR | Sebastian Huber | 2012-10-12 | 2 | -0/+6 |
* | bsp/lpc24xx: Fix PCLK clock divider calculation | Sebastian Huber | 2012-10-12 | 1 | -1/+1 |
