* acinclude.m4: Add BSP for GDB ARM simulator so we can easily
experiment with and debug different ARM architectural variations.
* .cvsignore, ChangeLog, Makefile.am, bsp_specs, configure.ac,
preinstall.am, console/.cvsignore, console/console-io.c,
include/.cvsignore, include/bsp.h, include/irq.h, include/swi.h,
start/.cvsignore, start/start.S, startup/.cvsignore,
startup/bspreset.c, startup/bspstart.c, startup/linkcmds,
startup/syscalls.c: New files.
* console/uart.c: Reflect termios_baud_to_number having been
renamed to rtems_termios_baud_to_number.
* shared/comm/console.c: Reflect termios_baud_to_number having been
Added bsp_start_memcpy(). Documentation. Changes for external ROM start.
* configure.ac: Resolve confusion with Ralf's patch.
* configure.ac, fb/fb.c, include/bsp.h: updates made for porting to
Nano-X and make testing easyer
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* include/ep7312.h, startup/bspreset.c: Move Skyeye magic address out
of .h file.
* misc/bspidle.c: Include bsp.h and fix prototype.
* configure.ac: Add default value.
* Makefile.am, preinstall.am, include/bsp.h: Rename BSP specific idle
thread to bsp_idle_thread.
* misc/bspidle.c: New file.
* include/idle.h, misc/idle.c: Removed.
* fb/fb.c: Register correct device name.
* startup/bspstart.c: Fix warnings.
* nds/fb/fb.c: took off get_screen_info() and set_screen_info() extern
references
* include/bsp.h: Eliminate BSPs defining NUMBER_OF_TERMIOS_PORTS.
Should be automatically handled by confdefs.h or the application.
* Makefile.am: Add fb/fb.c add rtl8019 Ethernet card support
* preinstall.am: Install skyeye_fb.h, Install wd80x3
* fb/fb.c, fb/skyeye_fb.h: Framebuffer support for skyeye simulator
* rtl8019/wd80x3, rtl8019/rtl8019.c: rtl8019 support
* startup/memmap.c: Change the size of Map I/O to 1216M
* bsp/bsp.h: Add rtl8019 related infomation
* fb/fb.c: function calls renamed; defined references to the extern
functions
* fb/fb.h: Removed.
* Makefile.am: Reflect removal.
* preinstall.am: Regenerated.
* fb/fb.c: different structures defined in rtems/fb.h that were used in
here so changes were needed
* Makefile.am, preinstall.am, fb/fb.c: Install nds specific .h files
into nds subdirectory.
* configure.ac, startup/bspreset.c: Add Skyeye reset device.
* Makefile.am, configure.ac: Add Skyeye reset device.
* startup/bspreset.c: New file.
* startup/linkcmds, startup/linkcmds.lpc2478,
startup/linkcmds.lpc2478_ncs, startup/linkcmds.lpc2478_ncs_ram:
Fixed dummy entries.
* clock/clockdrv.c: Tinker with clock on Skyeye.
* clock/clockdrv.c: Add stub nanoseconds since last tick handler to
improve coverage.
* fb/fb.c: changed the references to mw_fb.h into fb.h
* network/network.c: Add csb637 PHY code based upon that in
MicroMonitor 1.17.
* configure.ac: undefine BSP_PRESS_KEY_FOR_RESET
* startup/bspreset.c, include/ep7312.h: Support skyeye shutdown device
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* configure.ac, clock/clockdrv.c, startup/bspreset.c: Adjust clock
initialization for clock tick so rtmonuse test now runs on Skyeye.
Joel added configure magic and place holder in bspreset.c for Skyeye
hardware reset device support.
* Makefile.am: Fix typo.
* Makefile.am: Complete update to current style.
* Makefile.am: Update to current style.
* bsp_specs: Fix warning for _start.
* start/start.S: Proper attribution for origin.
* startup/bspstart.c: Add Skyeye bsp_reset() on Skyeye.
* include/.cvsignore: New file.
* include/bspopts.h.in: Removed.
* Makefile.am, configure.ac, console/uarts.c: Add console device that
uses MicroMonitor to do actual input and output. This driver should
work on any board that uses MicroMonitor.
* startup/linkcmds, startup/linkcmds.csb637: Move .init section from
the front of the executable so the start label has the first
instruction in the executable.
* Makefile.am, preinstall.am: Make an RTEMS specific umon.h wrapper
include file.
* Makefile.am: Re-add basic console code.
* Makefile.am: Add MicroMonitor support.
* Makefile.am, preinstall.am: Add MicroMonitor support.
* startup/umonsupp.c: New file.
* network/network.c: Attempt to support csb637 PHY.
* startup/linkcmds: Fix spacing.
