* configure.ac: Add RTEMS_BSPOPTS_*(ARM_RDP_MONITOR).
* startup/Makefile.am: Remove ARM_RDP_MONITOR, AM_CPPFLAGS.
* configure.ac: Add RTEMS_BPSOPTS_* for ARM_RDI_MONITOR.
* timer: New subdirectory.
* timer/Makefile.am: New file.
* timer/.cvsignore: New file.
* Makefile.am: Modified to reflect above.
* configure.ac: Ditto.
* wrapup/Makefile.am: Ditto.
* include/bsp.h: Stubs to let tm27 compile and link.
* console/console-io.c: Fixed typo.
* configure.in: Remove.
* acinclude.m4: New file.
* irq/Makefile.am: Use 'PREINSTALL_FILES ='.
* comm/Makefile.am: Use 'PREINSTALL_FILES ='.
* comm/Makefile.am: Use *_HEADERS instead of *H_FILES.
* configure.in: remove shared/io/Makefile.
* configure.in: Add include/bspopts.h.
* console/Makefile.am: Use *_HEADERS instead of *H_FILES.
* irq/Makefile.am: Use *_HEADER instead of *H_FILES.
* include/.cvsignore: Add bspopts.h*, coverhd.h, stamp-h*
* include/Makefile.am: Add bspopts.h, Use *_HEADER instead of *H_FILES.
* include/bsp.h: Add bspopts.h.
* configure.in: Reworked for Canadian Cross support.
* config.guess, config.sub: Update from subversions.gnu.org.
* README.cdn-X: New file.
* tools/Makefile.am: Remove build, tools from SUBDIRS.
* include/bsp.h: Added closing brace for extern C.
* console/console-io.c: Added console_initialize_hardware().
* clock: New directory with stub clock driver.
* clock/.cvsignore, clock/Makefile.am, clock/clockdrv.c: New files.
* Makefile.am, configure.in, wrapup/Makefile.am: Modified
to reflect above.
* startup/bspstart.c: Removed call of console_reserve_resources().
* wrapup/Makefile.am: Corrected typo so BSP components are picked up.
* comm/console.c: Added casts to eliminate warnings.
* comm/console.c (console_reserve_resources): Removed.
* startup/bspstart.c: Removed unused variables ramSpace and _end.
Added prototype for initialize_monitor_handles().
* startup/syscalls.c: Added casts and removed unused variables to
eliminate warnings.
* Makefile.am: Add include of bsp.am. Add clock subdirectory.
* configure.in: Add clock subdirectory.
* include/Makefile.am: Add coverhd.h.
* Makefile.am, console/Makefile.am, include/Makefile.am,
start/Makefile.am: VPATH was not setup correctly
* bsp_specs: Remove -Tlinkcmds from *link rule.
* configure.in, Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros.
* bsp_specs, console/Makefile.am, include/Makefile.am: Clean up.
* Makefile.am, bsp_specs, configure.in, console/Makefile.am,
include/Makefile.am, irq/Makefile.am, irq/irq.c, start/Makefile.am,
startup/Makefile.am, startup/exit.c, wrapup/Makefile.am:
Made to conform to current practice concerning automake and
autoconf. Corrected minor warnings.
* vegaplus BSP submitted by Emmanuel Raguet <raguet@crf.canon.fr> and
Eric Valette <valette@crf.canon.fr>.
* vegaplus/bsp_specs, configure.in, console/Makefile.am,
include/Makefile.am, include/bsp.h, include/registers.h,
irq/Makefile.am, irq/bsp_irq_asm.S, irq/bsp_irq_init.c, irq/irq.c,
irq/irq.h, start/Makefile.am, start/start.S, startup/Makefile.am,
startup/bspstart.c, startup/exit.c, startup/linkcmds,
wrapup/Makefile.am: New files.
* Makefile.am, shared/Makefile.am, shared/comm/Makefile.am,
shared/irq/Makefile.am: Include compile.am
startup/Makefile.am, wrapup/Makefile.am: Include compile.am
* clock/Makefile.am, console/Makefile.am, irq/Makefile.am,
start/Makefile.am, startup/Makefile.am, wrapup/Makefile.am:
Include compile.am.
That BSP now has a stub clock driver so the tests can link even
if they won't execute. A handful of Makefiles had to be updated
and we had to account for printk.c being a shared file now.
