Update #2408.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3387.
Update #3285.
Update #3285.
This was used by the not supported "make dist".
Update #3285.
Update #3285.
Update #3285.
upgrade to that version.
Close #3387.
These are now built to executables and are too large for this BSP.
Update #3382
Update #3285.
Update #3285.
Update #3285.
The umon support is only used by the csb337 BSP.
Update #3285.
Update #3285.
Update #3285.
This adds a simple function for setting the PIO drive strength.
Update #3285.
This patch fixes the cache handling for the atsam SPI driver. Note that
this solution might doesn't have the best performance for small packets.
The SPI controller supports a decoder connected to the chip select
lines. This patch allows to use this mode.
Update #3290.
* bsps/shared/cache
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3254.
Update #3254.
This is necessary to pick up mandatory flags provided by the build
system.
Update #3254.
Update #3254.
EXTRA_DIST += foobar
in fragments.
Update #3254.
Update #3254.
Updates #3520.
Removed reserved memory from work area, e.g. used by FPGA devices.
Use FDT to adjust the work area. Reduce work area of linker command
file.
