* configure.ac: Remove shared/comm/Makefile, shared/irq/Makefile.
* irq/Makefile.am: Add preinstallation dirstamp support.
* network/Makefile.am: Cosmetics.
* Makefile.am: Merge-in comm/Makefile.am, irq/Makefile.am
* comm/Makefile.am: Remove.
* irq/Makefile.am: Remove.
* irq/Makefile.am: Remove all-local: $(ARCH).
* acinclude.m4: Reflect changes to bootstrap.
* configure.ac: Remove RTEMS_CHECK_CUSTON_BSP.
* Makefile.am: Remove refs to non-existing files include/bspio.h and
include/uart.h.
Reflect changes to bsp.am.
* bsp_specs: Remove *lib:.
PR 480/bsps
* shared/irq/irq_asm.S: Remove duplicate code.
* console/console-io.c, include/bsp.h, startup/bspstart.c: URL for
license changed.
* include/bsp.h, include/registers.h, irq/bsp_irq_asm.S,
irq/bsp_irq_init.c, irq/irq.c, irq/irq.h, start/start.S,
startup/bspstart.c, startup/exit.c: URL for license changed.
* comm/console.c, comm/uart.c, comm/uart.h, irq/irq_asm.S,
irq/irq_init.c: URL for license changed.
* clock/clockdrv.c, console/uart.c, include/bsp.h, include/ep7312.h,
irq/bsp_irq_asm.S, irq/bsp_irq_init.c, irq/irq.c, irq/irq.h,
start/start.S, startup/bspstart.c, startup/exit.c, startup/linkcmds,
timer/timer.c: URL for license changed.
irq/Makefile.am: Reflect having moved automake.
comm/Makefile.am: Reflect having moved automake.
* startup/Makefile.am: Remove USE_INIT_FINI.
* bsp_specs: Remove -DUSE_ENHANCED_INTR_API.
* startup/linkcmds: Add FreeBSD SYSCTL() sections for networking.
* irq/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* configure.ac, network/Makefile.am: Don't build if networking disabled.
* startup/linkcmds: Add sections to remove warnings.
* network/network.c: Fix inconsistency in prototyping.
* network/network.c: Removed warning per Jay's suggestion.
* include/.cvsignore: Corrected.
* network/.cvsignore: New file.
* acinclude.m4: Added edb7312.
* New BSP.
* .cvsignore, ChangeLog, Makefile.am, bsp_specs, configure.ac, README,
times, clock/.cvsignore, clock/Makefile.am, clock/clockdrv.c,
console/.cvsignore, console/Makefile.am, console/uart.c,
include/ep7312.h, irq/.cvsignore, irq/Makefile.am, irq/bsp_irq_asm.S,
irq/bsp_irq_init.c, irq/irq.c, irq/irq.h, network/Makefile.am,
network/network.c, start/.cvsignore, start/Makefile.am,
start/start.S, startup/.cvsignore, startup/Makefile.am,
timer/.cvsignore, timer/Makefile.am, timer/timer.c,
wrapup/.cvsignore, wrapup/Makefile.am: New file.
* irq/irq_asm.S, irq/irq_init.c: Fixes a bug with handling the
situation where we are processing an IRQ, and we receive an FIQ.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
