This avoids consumption of a loadable address space for the nocache
heap.
According to the C11 and C++11 memory models only a read-modify-write
operation guarantees that we read the last value written in modification
order. Avoid the sequential consistent thread fence and instead use the
inter-processor interrupt to set the thread dispatch necessary
indicator.
Further documentation can be found in
https://devel.rtems.org/wiki/GSoC/2015/RaspberryPi_peripherals_and_SD_card
and test data (including sample user applications, device drivers and wiring schemes) can be found in
https://github.com/asuol/RTEMS_rpi_testing
flush_data_cache uses R0 directly but doesn't list it as a clobbered
register. Compiling with -O3 made this code break, since the function
that calls flush_data_cache already uses r0.
closes #2416.
Close #2385.
GPIO Driver Development for BeagleBone Black based on the generic GPIO API
makes rtems_gpio_bsp_get_value return uint32_t. Motivation: simplify
beagle gpio implementation for common gpio apio.
Added support for the new RTEMS GPIO API functions.
Test cases can be found in https://github.com/asuol/RTEMS_rpi_testing/tree/master/GPIO
This would lead to link-time errors in case less specialized compiler
machine options are used, e.g. to run the GCC test suite.
Signed-off-by: Premysl Houdek <kom541000@gmail.com>
there is no need to define access macros for field covering
whole registers. In addition, BSP_FLD32 does not work right
for field 32bit length.
The update fixes breakage of TMS570 support after Alexander Krutwig
switch of RTEMS time read to timecounter mechanism
bsps: Convert clock drivers to use a timecounter
Mechanism to specify odd (non 1 Mhz) time base update frequencies
implemented after objections of Martin Galvan.
Code is adjusted to convert RTEMS configuration parameter
microseconds_per_tick to such odd base if
TMS570_PREFERRED_TC_FREQUENCY is specified appropriately.
Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz>
The header files are generated by script make_header.py.
Current script's version can be found at:
https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python
Registers offsets and fields have been extracted from reference manual.
These files were left after running the script in the previous patch.
do
echo $b
# echo $g
-i $b
done
counter
timer interrupt was hard coded to 10 ms per tick.
Fix uses the setting of CONFIGURE_MICROSECONDS_PER_TICK to compute the correct start value for the counter
See for more information: http://permalink.gmane.org/gmane.os.rtems.user/22691
Fix typo.
closes 2345.
Update #2271.
Close #2303.
This patch adds support for the following devices to the LPC176x BSP:
* CAN
* PWM
* ADC
It also adds the probe routines for UART1/2/3 to the console_device_table in console-config.c, and enables UART1 in configure.ac.
This patch adds a BSP variant for the Raspberry Pi 2. You can
build both variants by configuring with the option
--enable-rtemsbsp="raspberrypi2 raspberrypi"
For the current BSP, the only change was the peripheral register base
address and the compiler options.
The raspberrypi/make/custom rules were re-factored:
raspberrypi.inc -- Common rules
raspberrypi.cfg -- Raspberry Pi 1 specific rule/optons
raspberrypi2.cfg -- Raspberry Pi 2 specific rule/options
I tested hello, ticker, unlimited, and paranoia on both the Pi (Model A+)
and Pi 2.
unused and poorly named (no prefix) and colliding with sp68.
Closes #2302.
