* | RaspberryPi: Use rtems_configuration_get_microseconds_per_tick to set clock ↵ | Jan Sommer | 2015-07-07 | 1 | -2/+4 | |
| | | | | | | | | counter timer interrupt was hard coded to 10 ms per tick. Fix uses the setting of CONFIGURE_MICROSECONDS_PER_TICK to compute the correct start value for the counter See for more information: http://permalink.gmane.org/gmane.os.rtems.user/22691 | |||||
* | bsps/arm: Update due to API changes | Sebastian Huber | 2015-06-26 | 1 | -2/+2 | |
* | beagle bsp: RTC support for BBB | ragunath | 2015-05-28 | 3 | -0/+283 | |
* | arm/shared/lpc/clock/lpc-clock-config.c: Remove unused variable warning | Joel Sherrill | 2015-05-21 | 1 | -1/+0 | |
* | Multiple bsp_specs: Change *(old_endfile) to %(old_endfile) | Joel Sherrill | 2015-05-21 | 21 | -21/+21 | |
| | | | | | | Fix typo. closes 2345. | |||||
* | bsp/tms570: Typo | Sebastian Huber | 2015-05-21 | 1 | -1/+1 | |
* | bsps: Convert clock drivers to use a timecounter | Alexander Krutwig | 2015-05-20 | 12 | -138/+110 | |
| | | | | Update #2271. | |||||
* | lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Add sptls02 | Joel Sherrill | 2015-04-23 | 1 | -0/+1 | |
* | lm3s3749-testsuite.tcfg: Add cdtest | Joel Sherrill | 2015-04-23 | 2 | -0/+2 | |
* | tms570/startup/bspreset.c: Add include <bsp/bootcard.h> to fix warning | Joel Sherrill | 2015-04-15 | 1 | -14/+15 | |
* | bsp/altera-cyclone-v: Add RTC driver | Thomas Volgmann | 2015-04-10 | 1 | -144/+622 | |
* | Add hardware FPU flags for Raspberry Pi 2 BSP | Alan Cudmore | 2015-04-09 | 1 | -1/+1 | |
* | rtl22xx-testsuite.tcfg: Add fileio | Joel Sherrill | 2015-04-03 | 1 | -0/+1 | |
* | bsp/altera-cyclone-v: Fix define usage | Sebastian Huber | 2015-04-02 | 1 | -1/+1 | |
* | TMS570: Add board reset code to bsp_reset | Martin Galvan | 2015-03-31 | 2 | -22/+34 | |
* | TMS570: Enable FPU in makefile. | Martin Galvan | 2015-03-27 | 1 | -1/+1 | |
* | bsp/altera-cyclone-v: Typo | Sebastian Huber | 2015-03-25 | 1 | -3/+3 | |
* | nds/libnds/source/arm9/image.c: Add needed cast | Joel Sherrill | 2015-03-24 | 1 | -1/+1 | |
* | nds/libnds/source/arm7/clock.c: Avoid over indexing array | Joel Sherrill | 2015-03-24 | 1 | -1/+1 | |
* | lpc176x/console/console-config.c: Conditionalize code to avoid unused warnings | Joel Sherrill | 2015-03-24 | 1 | -0/+4 | |
* | Replace www.rtems.com with www.rtems.org | Sebastian Huber | 2015-03-20 | 54 | -54/+54 | |
* | bsp/rtl22xx: Add prefix due to name conflicts | Sebastian Huber | 2015-03-20 | 1 | -5/+5 | |
| | | | | Close #2303. | |||||
* | Add CAN, PWM, ADC and UART1/2/3 support to the LPC176x BSP. | Martin Galvan | 2015-03-20 | 19 | -8/+1879 | |
| | | | | | | | | | | This patch adds support for the following devices to the LPC176x BSP: * CAN * PWM * ADC It also adds the probe routines for UART1/2/3 to the console_device_table in console-config.c, and enables UART1 in configure.ac. | |||||
* | arm/lpc24xx/make/custom/lpc23xx_tli800-testsuite.tcfg: Add tmfine01 | Joel Sherrill | 2015-03-17 | 1 | -0/+1 | |
* | arm/lpc24xx/make/custom/lpc2362-testsuite.tcfg: Add tmfine01 | Joel Sherrill | 2015-03-17 | 1 | -0/+1 | |
* | arm/lpc176x/make/custom/lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Add tmfine01 | Joel Sherrill | 2015-03-17 | 1 | -0/+1 | |
* | arm/lpc176x/make/custom/lpc1768_mbed_ahb_ram-testsuite.tcfg: Add tmfine01 | Joel Sherrill | 2015-03-17 | 1 | -0/+1 | |
* | arm/lpc176x/make/custom/lpc1768_mbed-testsuite.tcfg: Add tmfine01 | Joel Sherrill | 2015-03-17 | 1 | -0/+1 | |
* | arm/lm3s69xx/make/custom/lm4f120-testsuite.tcfg: Add tmfine01 | Joel Sherrill | 2015-03-17 | 1 | -0/+1 | |
* | preliminary Raspberry Pi Model 2 support | Alan Cudmore | 2015-03-16 | 6 | -22/+55 | |
| | | | | | | | | | | | | | | | | | This patch adds a BSP variant for the Raspberry Pi 2. You can build both variants by configuring with the option --enable-rtemsbsp="raspberrypi2 raspberrypi" For the current BSP, the only change was the peripheral register base address and the compiler options. The raspberrypi/make/custom rules were re-factored: raspberrypi.inc -- Common rules raspberrypi.cfg -- Raspberry Pi 1 specific rule/optons raspberrypi2.cfg -- Raspberry Pi 2 specific rule/options I tested hello, ticker, unlimited, and paranoia on both the Pi (Model A+) and Pi 2. | |||||
* | beagle bsp: delete TIMER_FREQ, TIMER_COUNT | Ben Gras | 2015-03-14 | 1 | -4/+0 | |
| | | | | | | unused and poorly named (no prefix) and colliding with sp68. Closes #2302. | |||||
* | rtl22xx.cfg: Remove -DNDEBUG flag | Joel Sherrill | 2015-03-09 | 1 | -1/+1 | |
* | lpc1768_mbed.cfg: Remove -DNDEBUG flag | Joel Sherrill | 2015-03-09 | 1 | -1/+1 | |
* | Add fsscandir01 variants as needed to more BSPs testsuite configuration | Joel Sherrill | 2015-03-06 | 12 | -0/+15 | |
* | raspberrypi: Do not include default IRQ handler and BSP specific one | Joel Sherrill | 2015-03-06 | 1 | -1/+0 | |
| | | | | | | This was tripping a linker error in the dl0[12] tests. closes 2247. | |||||
* | lpc1768_mbed_ahb_ram-testsuite.tcfg: Add ftp01 | Joel Sherrill | 2015-03-06 | 1 | -0/+1 | |
* | lpc1768_mbed_ahb_ram.tcfg: Remove as it is a junk file | Joel Sherrill | 2015-03-06 | 1 | -7/+0 | |
| | | | | | This file does not have "-testsuite" in the name and is ignored by the build system. | |||||
* | Fix a number of minor Doxygen formatting issues | Joel Sherrill | 2015-03-06 | 1 | -1/+1 | |
* | ARM: Add BSP_START_NEEDS_REGISTER_INITIALIZATION | Martin Galvan | 2015-02-27 | 4 | -0/+139 | |
| | | | | | | | | | | | | | This patch adds the macro BSP_START_NEEDS_REGISTER_INITIALIZATION and three hooks for BSP-specific register init code to arm/shared/start.S. Said hooks are bsp_start_init_registers_core (intended for initializing the ARM core registers), bsp_start_init_registers_banked_fiq (for the FIQ mode banked registers) and bsp_start_init_registers_vfp (for the FPU registers). BSP_START_NEEDS_REGISTER_INITIALIZATION would be defined in a BSP's configure.ac (so that it appears in its bspopts.h). This patch also adds the register init code required by the TMS570. We've tested it with the tms570ls3137_hdk.cfg config and it works fine. | |||||
* | ARM: Support VFP-D16 | Martin Galvan | 2015-02-20 | 1 | -3/+5 | |
| | | | | | | | | | This patch allows the existing FPU code to support both VFP-D16 and VFP-D32. According to ARM, writes to D32DIS are ignored for D16 so there's no need to enclose the bic instruction with an #ifdef. We tested it on a TMS570LS3137 using TI initialization code and it works fine. Signed-off by: Martin Galvan <martin.galvan@tallertechnologies.com> | |||||
* | score: Add _CPU_SMP_Prepare_start_multitasking() | Sebastian Huber | 2015-02-17 | 1 | -0/+5 | |
| | | | | Update #2268. | |||||
* | lpc1768_mbed_ahb_ram_eth-testsuite.tcfg: Add ftp01 | Joel Sherrill | 2015-02-13 | 1 | -0/+1 | |
* | lpc1768_mbed-testsuite.tcfg: Add ftp01 | Joel Sherrill | 2015-02-13 | 1 | -0/+1 | |
* | arm/tms570: sci context has to be writable because it holds state variable. | Pavel Pisa | 2015-02-04 | 2 | -4/+4 | |
| | | | | | | | | | | | | | | The structure tms570_sci_context holds state variable tx_chars_in_hw which holds if and how many characters (in the optional FIFO support for some Ti SCIs) are submitted into hardware. When field is not writable then code breaks when RTEMS is build for Flash area. The problem found and analyzed by Martin Galvan from tallertechnologies. Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz> | |||||
* | stm32f4/.../stm32f105rc-testsuite.tcfg: Add more tests | Joel Sherrill | 2015-01-23 | 1 | -0/+1 | |
* | lpc24xx/.../lpc23xx_tli800-testsuite.tcfg: Add more tests | Joel Sherrill | 2015-01-23 | 1 | -0/+7 | |
* | lpc24xx/.../lpc2362-testsuite.tcfg: Add more tests | Joel Sherrill | 2015-01-23 | 1 | -0/+2 | |
* | lm3s69xx/.../lm3s6965-testsuite.tcfg: Add more tests | Joel Sherrill | 2015-01-23 | 1 | -0/+1 | |
* | lm3s69xx/.../lm3s3749-testsuite.tcfg: Add more tests | Joel Sherrill | 2015-01-23 | 1 | -0/+2 | |
* | bsp/altera-cyclone-v: Use proper free function | Sebastian Huber | 2015-01-23 | 1 | -1/+1 | |
