* acinclude.m4: Removed vegaplus BSP.
* vegaplus/.cvsignore, vegaplus/ChangeLog, vegaplus/Makefile.am,
vegaplus/bsp_specs, vegaplus/configure.ac, vegaplus/clock/clockdrv.c,
vegaplus/include/.cvsignore, vegaplus/include/bsp.h,
vegaplus/include/registers.h, vegaplus/include/tm27.h,
vegaplus/irq/bsp_irq_asm.S, vegaplus/irq/bsp_irq_init.c,
vegaplus/irq/irq.c, vegaplus/irq/irq.h, vegaplus/start/start.S,
vegaplus/startup/bspstart.c, vegaplus/startup/exit.c,
vegaplus/startup/linkcmds: Removed.
* Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* Makefile.am: Remove build-variant support.
* startup/linkcmds: Add .gnu.linkonce.b section.
PR 610/bsps
* Makefile.am: Add include/tm27.h, Cosmetics.
* include/tm27.h: Final cosmetics.
* include/tm27.h: New.
* startup/bspstart.c: Convert to using c99 fixed size types.
* startup/linkcmds: Add more memory so tests can link. This is a
generic BSP for a CPU model so OK to do this.
* Makefile.am: Reflect changes to bsp.am.
Preinstall dist_project_lib*.
* Makefile.am: Use CPPASCOMPILE instead of CCASCOMPILE.
* Makefile.am: Pickup files from ../../arm/shared instead of
../shared. Reformat.
* configure.ac: Add nostdinc to AUTOMAKE_OPTIONS.
Add RTEMS_PROG_CCAS.
irq/Makefile.am, start/Makefile.am, startup/Makefile.am,
timer/Makefile.am, wrapup/Makefile.am. Use automake compilation rules.
* clock/Makefile.am, console/Makefile.am, irq/Makefile.am,
wrapup/Makefile.am: Remove.
* irq/Makefile.am: Ditto.
* start/Makefile.am: Ditto.
* startup/Makefile.am: Ditto.
* wrapup/Makefile.am: Eliminate $(LIB).
Use noinst_DATA to trigger building libbsp.a.
* startup/linkcmds: Remove SEARCH_DIR.
* irq/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* irq/Makefile.am: Remove all-local: $(ARCH).
* bsp_specs: Remove *lib:.
* include/bsp.h, include/registers.h, irq/bsp_irq_asm.S,
irq/bsp_irq_init.c, irq/irq.c, irq/irq.h, start/start.S,
startup/bspstart.c, startup/exit.c: URL for license changed.
irq/Makefile.am: Reflect having moved automake.
* bsp_specs: Remove -DUSE_ENHANCED_INTR_API.
* startup/linkcmds: Add FreeBSD SYSCTL() sections for networking.
* irq/Makefile.am: Don't include @RTEMS_BSP@.cfg.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* irq/Makefile.am: Use .$(OBJEXT) instead of .o.
* irq_bsp_irq_asm.S: Update to reflect irq_asm modifications.
