path: root/c/src/lib/libbsp/arm/vegaplus/ChangeLog (follow)
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-111-0/+6
* 2001-09-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-271-0/+6
| | | | | | * include/Makefile.am: Use 'CLEANFILES ='. * include/Makefile.am: Use 'TMPINSTALL_FILES ='. * irq/Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-05-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-241-0/+8
| | | | | | | | | * configure.in: Add include/bspopts.h. * console/Makefile.am: Use *_HEADERS instead of *H_FILES. * irq/Makefile.am: Use *_HEADER instead of *H_FILES. * include/.cvsignore: Add bspopts.h*, coverhd.h, stamp-h* * include/Makefile.am: Add bspopts.h, Use *_HEADER instead of *H_FILES. * include/bsp.h: Add bspopts.h.
* 2001-05-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-111-0/+4
| | | | * configure.in: Use RTEMS_PROG_CC_FOR_TARGET([-ansi -fasm]).
* 2001-01-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-081-0/+4
| | | | * include/bsp.h: Added closing brace for extern C.
* 2001-01-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-031-0/+7
| | | | | | | * clock: New directory with stub clock driver. * clock/.cvsignore, clock/Makefile.am, clock/clockdrv.c: New files. * Makefile.am, configure.in, wrapup/Makefile.am: Modified to reflect above.
* 2000-12-06 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-061-0/+5
| | | | | * startup/bspstart.c: Removed call of console_reserve_resources(). * wrapup/Makefile.am: Corrected typo so BSP components are picked up.
* 2000-11-10 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-101-0/+5
| | | | | * Makefile.am, console/Makefile.am, include/Makefile.am, start/Makefile.am: VPATH was not setup correctly
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-091-0/+4
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-021-0/+4
* 2000-11-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-011-0/+7
| | | | | | | * startup/bspstart.c: assoc.h, error.h, libio_.h, libio.h, and libcsupport.h moved from libc to lib/include/rtems and now must be referenced as <rtems/XXX.h>. Header file order was cleaned up while doing this.
* 2000-10-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-271-0/+5
* 2000-09-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-131-0/+8
| | | | | | | | * Makefile.am, bsp_specs, configure.in, console/Makefile.am, include/Makefile.am, irq/Makefile.am, irq/irq.c, start/Makefile.am, startup/Makefile.am, startup/exit.c, wrapup/Makefile.am: Made to conform to current practice concerning automake and autoconf. Corrected minor warnings.
* 2000-09-13 Emmanuel Raguet <raguet@crf.canon.fr>Joel Sherrill2000-09-131-0/+4
* vegaplus BSP submitted by Emmanuel Raguet <raguet@crf.canon.fr> and Eric Valette <valette@crf.canon.fr>. * vegaplus/bsp_specs, configure.in, console/Makefile.am, include/Makefile.am, include/bsp.h, include/registers.h, irq/Makefile.am, irq/bsp_irq_asm.S, irq/bsp_irq_init.c, irq/irq.c, irq/irq.h, start/Makefile.am, start/start.S, startup/Makefile.am, startup/bspstart.c, startup/exit.c, startup/linkcmds, wrapup/Makefile.am: New files.
