TMS570LS3135ZWT chip.
Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz>
remarks.
Signed-off-by: Premysl Houdek <kom541000@gmail.com>
boot loader.
The default tms570ls3137_hdk variant is for building RTEMS
application image starting directly from start of Flash.
Variant tms570ls3137_hdk_with_loader skips 256kB at start
of Flash to allow use with application loader.
Parameters overlay module is initialized and cleared first.
It is used later to replace exception target vectors
only if that is required.
The application loader code with CPU and SDRAM setup
code has to provide well defined pattern of instructions
at addresses 0x00000000 and 0x0000001f, because only data
read accesses can be processed reliably by POM. The expected
instruction pattern can be seen in the next example
https://github.com/hornmich/tms570ls3137-hdk-sdram/blob/master/SDRAM_SCI_configuration/source/sys_intvecs.asm
Comments with detailed description of code, background
and reasons for selected approach have been included
in TMS570 bsp startup code.
tms570_sci_interrupt_last_close: do not wait for old data transmit.
there is no need to define access macros for field covering
whole registers. In addition, BSP_FLD32 does not work right
for field 32bit length.
The update fixes breakage of TMS570 support after Alexander Krutwig
switch of RTEMS time read to timecounter mechanism
bsps: Convert clock drivers to use a timecounter
Mechanism to specify odd (non 1 Mhz) time base update frequencies
implemented after objections of Martin Galvan.
Code is adjusted to convert RTEMS configuration parameter
microseconds_per_tick to such odd base if
TMS570_PREFERRED_TC_FREQUENCY is specified appropriately.
The header files are generated by script make_header.py.
Current script's version can be found at:
https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python
Registers offsets and fields have been extracted from reference manual.
Fix typo.
closes 2345.
Update #2271.
This patch adds the macro BSP_START_NEEDS_REGISTER_INITIALIZATION and
three hooks for BSP-specific register init code to arm/shared/start.S.
Said hooks are bsp_start_init_registers_core (intended for initializing
the ARM core registers), bsp_start_init_registers_banked_fiq (for the
FIQ mode banked registers) and bsp_start_init_registers_vfp (for the FPU
registers). BSP_START_NEEDS_REGISTER_INITIALIZATION would be defined in
a BSP's configure.ac (so that it appears in its bspopts.h).
This patch also adds the register init code required by the TMS570.
We've tested it with the tms570ls3137_hdk.cfg config and it works fine.
The structure tms570_sci_context holds state variable
tx_chars_in_hw which holds if and how many characters
(in the optional FIFO support for some Ti SCIs) are submitted
into hardware.
When field is not writable then code breaks when RTEMS
is build for Flash area.
The problem found and analyzed by Martin Galvan from tallertechnologies.
This section can be use to provide a cache coherent memory area via
rtems_cache_coherent_add_area().
Move interrupt lock to device context and expose only this structure to
the read, write and set attributes device handler. This makes these
device handler independent of the general Termios infrastructure
suitable for direct use in printk() support.
Fix build error introduced in f535fe5311978af53635c2da8e5cb10ef9d78802.
output.
not updated.
counters.
The code is written as BSP specific now but it should work for all
Cortex-A and R based CPUs and can be moved to ARM generic place in future.
StackOverflow suggested sequences of writes to the registers required
to start counters is used.
http://stackoverflow.com/questions/3247373/how-to-measure-program-execution-time-in-arm-cortex-a8-processor
BSP completes build with tests and debug enabled for all three variants now
tms570ls3137_hdk
tms570ls3137_hdk_intram
tms570ls3137_hdk_sdram
Even that all enabled tests builds for internal RAM variant, many
of them are expected to fail on hardware because whole tests
including code, data and runtime work area demands has to fit
into 256 kB of RAM.
requirements.
This patch enables to build all RTEMS tests for tms570ls3137_hdk_sdram
BSP variant in in default build. Debug build with --enable-rtems-debug set
has succeed for samples subset of tests as well.
Included variants:
tms570ls3137_hdk_intram - place code and data into internal SRAM
tms570ls3137_hdk_sdram - place code into external SDRAM and data to SRAM
tms570ls3137_hdk - variant prepared for stand-alone RTEMS aplication
stored and running directly from flash. Not working yet.
Chip initialization code not included in BSP.
External startup generated by TI's HalCoGen was used for
testing and debugging.
More information about TMS570 BSP can be found at
http://www.rtems.org/wiki/index.php/Tms570
Patch version 2
- most of the formatting suggestion applied.
- BSP converted to use clock shell
- console driver "set attributes" tested. Baudrate change working
Patch version 3
- more formatting changes.
- removed leftover defines and test functions
Todo:
refactor header files (name register fields)
