Generated header file ti_herc/reg_spi.h contains complete registers
and fields set for Ti MibSPI peripheral.
Care has to be taken that only TMS570_SPI1, TMS570_SPI3 and TMS570_SPI5
are of this complete multibuffer type. TMS570_SPI2 and TMS570_SPI4
have substantial part of registers removed but else they are compatible.
clear of alt outputs.
TMS570LS3135ZWT chip.
remarks.
Signed-off-by: Premysl Houdek <kom541000@gmail.com>
Parameters overlay module is initialized and cleared first.
It is used later to replace exception target vectors
only if that is required.
The application loader code with CPU and SDRAM setup
code has to provide well defined pattern of instructions
at addresses 0x00000000 and 0x0000001f, because only data
read accesses can be processed reliably by POM. The expected
instruction pattern can be seen in the next example
https://github.com/hornmich/tms570ls3137-hdk-sdram/blob/master/SDRAM_SCI_configuration/source/sys_intvecs.asm
Comments with detailed description of code, background
and reasons for selected approach have been included
in TMS570 bsp startup code.
Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz>
there is no need to define access macros for field covering
whole registers. In addition, BSP_FLD32 does not work right
for field 32bit length.
The header files are generated by script make_header.py.
Current script's version can be found at:
https://github.com/AoLaD/rtems-tms570-utils/tree/headers/headers/python
Registers offsets and fields have been extracted from reference manual.
The structure tms570_sci_context holds state variable
tx_chars_in_hw which holds if and how many characters
(in the optional FIFO support for some Ti SCIs) are submitted
into hardware.
When field is not writable then code breaks when RTEMS
is build for Flash area.
The problem found and analyzed by Martin Galvan from tallertechnologies.
Move interrupt lock to device context and expose only this structure to
the read, write and set attributes device handler. This makes these
device handler independent of the general Termios infrastructure
suitable for direct use in printk() support.
requirements.
This patch enables to build all RTEMS tests for tms570ls3137_hdk_sdram
BSP variant in in default build. Debug build with --enable-rtems-debug set
has succeed for samples subset of tests as well.
Included variants:
tms570ls3137_hdk_intram - place code and data into internal SRAM
tms570ls3137_hdk_sdram - place code into external SDRAM and data to SRAM
tms570ls3137_hdk - variant prepared for stand-alone RTEMS aplication
stored and running directly from flash. Not working yet.
Chip initialization code not included in BSP.
External startup generated by TI's HalCoGen was used for
testing and debugging.
More information about TMS570 BSP can be found at
http://www.rtems.org/wiki/index.php/Tms570
Patch version 2
- most of the formatting suggestion applied.
- BSP converted to use clock shell
- console driver "set attributes" tested. Baudrate change working
Patch version 3
- more formatting changes.
- removed leftover defines and test functions
Todo:
refactor header files (name register fields)
