path: root/c/src/lib/libbsp/arm/tms570/README (follow)
* arm/tms570: document BSP setup with included hardware initialization.Pavel Pisa2016-10-021-22/+100
* bsp/tms570: separate Flash variants to one which boots directly and one for ↵Premysl Houdek2015-11-181-0/+3
| | | | | | | | | | | | boot loader. The default tms570ls3137_hdk variant is for building RTEMS application image starting directly from start of Flash. Variant tms570ls3137_hdk_with_loader skips 256kB at start of Flash to allow use with application loader. Signed-off-by: Pavel Pisa <pisa@cmp.felk.cvut.cz>
* BSP for TMS570LS31x Hercules Development Kit from TI (TMS570LS3137)Premysl Houdek2014-08-201-0/+67
Included variants: tms570ls3137_hdk_intram - place code and data into internal SRAM tms570ls3137_hdk_sdram - place code into external SDRAM and data to SRAM tms570ls3137_hdk - variant prepared for stand-alone RTEMS aplication stored and running directly from flash. Not working yet. Chip initialization code not included in BSP. External startup generated by TI's HalCoGen was used for testing and debugging. More information about TMS570 BSP can be found at http://www.rtems.org/wiki/index.php/Tms570 Patch version 2 - most of the formatting suggestion applied. - BSP converted to use clock shell - console driver "set attributes" tested. Baudrate change working Patch version 3 - more formatting changes. - removed leftover defines and test functions Todo: refactor header files (name register fields)
