Many files had an extra blank line in the license text
found in the file header. This patch removes that line.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.rtems.com/license/LICENSE.
The script that did this also turned off execute permission
when it was turned on incorrectly.
PR 1917/bsps
* Makefile.am: Modifications to add dynamic tables for libchip serial
drivers.
* startup/bspreset.c:
* gba/clock/clockdrv.c, gba/console/conio.c, gba/console/console.c,
gba/console/defaultfont.h, gba/include/arm_mode_bits.h,
gba/include/asm_macros.h, gba/include/bsp.h, gba/include/conio.h,
gba/include/gba.h, gba/include/gba_registers.h, gba/irq/irq.c,
gba/irq/irq.h, gba/startup/bspstart.c, gba/timer/timer.c,
gp32/include/bsp.h, gp32/startup/bspreset.c, gp32/startup/bspstart.c,
nds/tools/runtest, shared/comm/uart.c, shared/comm/uart.h,
smdk2410/include/bsp.h: Fix typo where license said
found in found in.
* startup/linkcmds: Use linker command base file.
* Makefile.am, preinstall.am: Added generic interrupt support modules.
* csb336/make/custom/csb336.cfg,
csb337/make/custom/csb337.cfg, edb7312/make/custom/edb7312.cfg,
gba/make/custom/gba.cfg, gdbarmsim/make/custom/arm920.cfg,
gp32/make/custom/gp32.cfg, gumstix/make/custom/gumstix.cfg,
lpc32xx/make/custom/lpc32xx_phycore.cfg, nds/make/custom/nds.cfg,
rtl22xx/make/custom/rtl22xx.cfg, smdk2410/make/custom/smdk2410.cfg:
Use VFP floating point model.
* make/custom/smdk2410.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/smdk2410.cfg: New (relocated from /make/custom).
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* Makefile.am, configure.ac: Add Skyeye reset device.
* startup/bspreset.c: New file.
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* bsp_specs: Move -e start from *link to *startfile to avoid warning
for undefined entry symbol when linking relocatables with binutils
2.19.
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Remove noinst_PROGRAMS (Unused).
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
PR 1322/bsps
* include/bspopts.h.in: Remove.
PR 1322/bsps
* configure.ac, include/bspopts.h.in: Make letting boot_card() handle
work area allocation mandatory. Rename
RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to BSP_BOOTCARD_OPTIONS.
* Makefile.am, configure.ac, include/bspopts.h.in: Use standardized
bsp_cleanup() which can optionally print a message, poll for user to
press key, and call bsp_reset(). Using this eliminates the various
bsp_cleanup() implementations which had their own implementation and
variety of string constants.
* startup/linkcmds: Move WorkAreaBase to be closer to end definition.
* startup/linkcmds: Add WorkAreaBase.
* Makefile.am, startup/linkcmds: Use top level shared
bsp_get_work_area() implementation.
* Makefile.am, configure.ac, include/bspopts.h.in: Split out
bsp_get_work_area() into its own file and user BSP Framework to
perform more initialization. Use same shared implementation as
edb7312 and csb336.
* Makefile.am: No BSP should use exit.c as a file name. exit() is POSIX
routine.
* Makefile.am, preinstall.am: Need tm27.h
* Makefile.am: Rework to avoid .rel files.
* .cvsignore: New file.
* Makefile.am: Use shared bsp_predriver_hook.
* include/bsp.h: Grammar.
* ChangeLog, Makefile.am, README, bsp_specs, configure.ac,
preinstall.am, include/bsp.h, include/bspopts.h.in, startup/linkcmds,
startup/memmap.c: New files.
