The TLS section symbols had wrong values in case of an empty TLS data
section and a nonempty TLS BSS section.
Add new methods which deliver the cache sizes of for supported cache levels.
This level 2 cache is a shared data and instruction cache and thus needs locking.
Correct misalignment handling and prepare for locking.
Arm erratum 764369 only applies to the level 1 cache.
It is importeant to consistently apply the same handling for flushing within
level 2 and level 1 cache handling. In this case now both handling use clean and invalidate.
Move the RTEMS_SMP conditional compilation to the detection method of arm erratum 764369
Execute the SCU part of the workaround of arm erratum 764368 after the SCU was enabled.
Add and use _CPU_SMP_Start_processor(). Add and use
_CPU_SMP_Finalize_initialization(). This makes most
_CPU_SMP_Initialize() functions a bit simpler since we can calculate the
minimum value of the count of processors requested by the application
configuration and the count of physically or virtually available
processors in the high-level code.
The CPU port has now the ability to signal a processor start failure.
With the support for clustered/partitioned scheduling the presence of
particular processors can be configured to be optional or mandatory.
There will be a fatal error only in case mandatory processors are not
present.
The CPU port may use a timeout to monitor the start of a processor.
Reduce MII clock to support LPC17XX.
arm-l2c-310/cache_.h contains the handling for the L2C-310
level 2 cache controller from arm. It references the arm
level 1 cache handling in the new file arm-cache-l1.h.
Rename rtems_smp_process_interrupt() into
_SMP_Inter_processor_interrupt_handler(). Delete unused header file
<rtems/bspsmp.h>.
Rename rtems_smp_secondary_cpu_initialize() into
_SMP_Start_multitasking_on_secondary_processor(). Move declaration to
<rtems/score/smpimpl.h>.
Since the per-CPU SMP lock must be acquired and released to send the
message a single interrupt broadcast operations offers no benefits. If
synchronization is required, then a SMP barrier must be used anyway.
Rename bsp_smp_initialize() into _CPU_SMP_Initialize() since every CPU
port must supply this function.
Merge RTEMS_FATAL_SOURCE_BSP_GENERIC and RTEMS_FATAL_SOURCE_BSP_SPECIFIC
into new fatal source RTEMS_FATAL_SOURCE_BSP. This makes it easier to
figure out the code position given a fatal source and code.
Use the Global Timer for the Cortex-A9 MPCore clock driver instead of
the Private Timer. This enables a consistent nanoseconds since last
context switch value across all processors.
This allows read-only vector tables in ROM. It avoids also an unsolved
problem with MMU/cache synchronization on SMP.
The ALIGN_WITH_INPUT helps to make this linker script more reliable.
See also:
https://sourceware.org/ml/binutils/2013-06/msg00246.html
https://sourceware.org/binutils/docs-2.24/ld/Forced-Output-Alignment.html#Forced-Output-Alignment
This reverts commit 4a9e52eefc510d7022ddc61c4ecde8db6b9a0217.
This reverts commit 1ab4f76900d012b5a9dbce2851add060f11ce13a.
This allows an application to provide a localised clock freq with
needing to go down the BSP opts path. This is important with the
Zynq where the Xilinx tools generate the frequency.
This reverts commit 287bbb65afd24ffc6254ae5f328733213f184205.
Conflicts:
c/src/lib/libbsp/arm/shared/startup/linkcmds.base
This requires at least Binutils 2.24.
