Use the previously unused TPIDRPRW register to get the per-CPU control
of the current processor. This avoids instructions in
GET_SELF_CPU_CONTROL which are not available in Thumb mode.
The symbol can be used by bsp_start_hook_0 when complete
RAM memory is initialization and overwritten during BSP
self-test. The test overwrites even memory used to store
return address / link register and regular resturn from
bsp_start_hook_0 is not possible then.
When HYP mode is detected at startup then setup HYP mode
vectors table (for future extensions) clean exceptions
switching to HYP mode and switch CPU to ARM SVC mode.
BSPs which want to use this support need to include next option
in their configure.ac
RTEMS_BSPOPTS_SET([BSP_START_IN_HYP_SUPPORT],[*],[1])
RTEMS_BSPOPTS_HELP([BSP_START_IN_HYP_SUPPORT], [Support start of BSP in ARM HYP mode])
AM_CONDITIONAL(BSP_START_IN_HYP_SUPPORT,test "$BSP_START_IN_HYP_SUPPORT" = "1")
and need to include next lines in corresponding Makefile.am
if BSP_START_IN_HYP_SUPPORT
libbsp_a_SOURCES += ../shared/startup/bsp-start-in-hyp-support.S
endif
This patch adds the macro BSP_START_NEEDS_REGISTER_INITIALIZATION and
three hooks for BSP-specific register init code to arm/shared/start.S.
Said hooks are bsp_start_init_registers_core (intended for initializing
the ARM core registers), bsp_start_init_registers_banked_fiq (for the
FIQ mode banked registers) and bsp_start_init_registers_vfp (for the FPU
registers). BSP_START_NEEDS_REGISTER_INITIALIZATION would be defined in
a BSP's configure.ac (so that it appears in its bspopts.h).
This patch also adds the register init code required by the TMS570.
We've tested it with the tms570ls3137_hdk.cfg config and it works fine.
This patch allows the existing FPU code to support both VFP-D16 and
VFP-D32. According to ARM, writes to D32DIS are ignored for D16 so
there's no need to enclose the bic instruction with an #ifdef. We tested
it on a TMS570LS3137 using TI initialization code and it works fine.
Signed-off by: Martin Galvan <martin.galvan@tallertechnologies.com>
This floating point unit is available in Cortex-M4 processors and
defined by ARMv7-M. This adds basic support for other VFP-D16 variants.
This allows read-only vector tables in ROM. It avoids also an unsolved
problem with MMU/cache synchronization on SMP.
Add and use _ARMV4_Exception_undef_default(),
_ARMV4_Exception_swi_default(), _ARMV4_Exception_data_abort_default(),
_ARMV4_Exception_pref_abort_default(),
_ARMV4_Exception_reserved_default(), _ARMV4_Exception_irq_default(), and
_ARMV4_Exception_fiq_default().
* shared/startup/bsp-start-copy-sections.c,
shared/startup/bsp-start-memcpy.S: New files.
* shared/include/start.h: Declare bsp_start_copy_sections().
* shared/start/start.S, shared/include/linker-symbols.h: Moved
content. Support for ARMv7-M.
* shared/start/start.S: Default exception handler will result in
bsp_reset().
* shared/startup/linkcmds.base: Move unsupported sections into
read-only section. Changed barrier sections.
* preinstall.am, shared/lpc/include/lpc-i2s.h,
shared/startup/linkcmds.armv4, shared/startup/linkcmds.armv7: New
files.
* Makefile.am: Added header and linker command files intended to be
used by every ARM BSP.
* shared/startup/linkcmds.base: Support for EABI and ARM ELF standard.
* shared/include/linker-symbols.h: Update due to linker command file
changes.
* shared/start/start.S, shared/include/start.h: Renamed entry symbol
from start to _start to avoid namespace conflicts. Update due to
linker command file changes.
PR 1719/cpukit
* shared/start/start.S: Avoid "bx" instruction to support ARMv4 and
below.
* shared/start/start.S, shared/startup/linkcmds.base,
shared/include/linker-symbols.h: Added and use bsp_vector_table_begin,
bsp_vector_table_size and bsp_vector_table_end.
added thumb support to start.S
updated documentation
Added bsp_start_memcpy(). Documentation. Changes for external ROM start.
* shared/start/start.S: Update for boot_card command line change.
* Makefile.am, configure.ac, preinstall.am: Added BSP variants.
* console/console-config.c, clock/clock-config.c, ssp/ssp.c: Fixed
register settings. Cleanup.
* include/bsp.h: Added network defines and functions.
* include/lpc24xx.h: Added AHB and EMC defines. Fixed Ethernet status
sizes.
* include/system-clocks.h, misc/system-clocks.c: Added micro seconds
delay function that uses Timer 1. Changed PLL setup.
* network/network.c, startup/bspreset.c, startup/linkcmds.lpc2478,
startup/linkcmds.lpc2478_ncs, startup/linkcmds.lpc2478_ncs_ram: New
files.
* startup/bspstart.c: Added EMC initialization. Changes for ROM boot.
