Update #2271.
Reduce MII clock to support LPC17XX.
This patch refactors a lot of the existing doxygen within libbsp/arm/lpc32xx.
Much of this refactoring was just renaming of existing groups to conform to a
more consistent naming structure. With the addition of a doxygen header for
tm27.h, all files within lpc32xx belong to doxygen group now. lpc32xx should
be used a reference for adding doxygen to other bsps.
All PHYs will be set to power up/down state with the BMCR[BMCR_PDOWN]
setting.
The KSZ80X1RNL will use the energy detect power down (EDPD) mode with
PLL automatically turned in the up state. It will use the slow
oscillator mode in the down state.
To prevent system bus lock-ups the PHY is set to the up state before
Ethernet module initialization. In case of a communication failure with
the PHY or weird PHY identifiers the initialization will be aborted.
The receive task will only hand over a mbuf if it gets a new one
immediately. This avoids mbuf migration out of the receive task in case
of overload.
Add reserved system events RTEMS_EVENT_SYSTEM_NETWORK_SBWAIT and
RTEMS_EVENT_SYSTEM_NETWORK_SOSLEEP.
Add and use rtems_bsdnet_event_send().
* shared/lpc/include/lpc-emc.h, shared/lpc/include/lpc-lcd.h: New
files.
* shared/lpc/include/lpc-dma.h: API changes.
* shared/lpc/clock/lpc-clock-config.c: Fixed nano seconds extension.
* shared/lpc/network/lpc-ethernet.c: Format. Multicast hash filter
support.
* shared/lpc/network/lpc-ethernet.c: Support multicast.
* shared/lpc/include/lpc-i2s.h: Documentation. Fixed defines.
* shared/lpc/include/lpc-timer.h: Documentation.
* shared/lpc/network/lpc-ethernet.c: Added support for 10MBit/s links.
* preinstall.am, shared/lpc/include/lpc-i2s.h,
shared/startup/linkcmds.armv4, shared/startup/linkcmds.armv7: New
files.
* Makefile.am: Added header and linker command files intended to be
used by every ARM BSP.
* shared/startup/linkcmds.base: Support for EABI and ARM ELF standard.
* shared/include/linker-symbols.h: Update due to linker command file
changes.
* shared/start/start.S, shared/include/start.h: Renamed entry symbol
from start to _start to avoid namespace conflicts. Update due to
linker command file changes.
added thumb support to start.S
updated documentation
