* shared/startup/bsp-start-copy-sections.c,
shared/startup/bsp-start-memcpy.S: New files.
* shared/include/start.h: Declare bsp_start_copy_sections().
* shared/start/start.S, shared/include/linker-symbols.h: Moved
content. Support for ARMv7-M.
* preinstall.am, shared/lpc/include/lpc-i2s.h,
shared/startup/linkcmds.armv4, shared/startup/linkcmds.armv7: New
files.
* Makefile.am: Added header and linker command files intended to be
used by every ARM BSP.
* shared/startup/linkcmds.base: Support for EABI and ARM ELF standard.
* shared/include/linker-symbols.h: Update due to linker command file
changes.
* shared/start/start.S, shared/include/start.h: Renamed entry symbol
from start to _start to avoid namespace conflicts. Update due to
linker command file changes.
* shared/start/start.S, shared/startup/linkcmds.base,
shared/include/linker-symbols.h: Added and use bsp_vector_table_begin,
bsp_vector_table_size and bsp_vector_table_end.
* shared/include/start.h: Define start section attributes.
Added bsp_start_memcpy(). Documentation. Changes for external ROM start.
* Makefile.am, configure.ac, preinstall.am: Added BSP variants.
* console/console-config.c, clock/clock-config.c, ssp/ssp.c: Fixed
register settings. Cleanup.
* include/bsp.h: Added network defines and functions.
* include/lpc24xx.h: Added AHB and EMC defines. Fixed Ethernet status
sizes.
* include/system-clocks.h, misc/system-clocks.c: Added micro seconds
delay function that uses Timer 1. Changed PLL setup.
* network/network.c, startup/bspreset.c, startup/linkcmds.lpc2478,
startup/linkcmds.lpc2478_ncs, startup/linkcmds.lpc2478_ncs_ram: New
files.
* startup/bspstart.c: Added EMC initialization. Changes for ROM boot.
