* shared/abort/abort.c, shared/abort/simple_abort.c:
* shared/abort/simple_abort.c: Add veneer for ARM<->Thumb
shared/irq/irq_asm.S: Add veneer for ARM<->Thumb
PR 1257/bsps
* csb336/network/lan91c11x.c, csb337/startup/bspstart.c,
edb7312/irq/irq.c, gba/irq/irq.c, gba/irq/irq_init.c,
gp32/startup/bspstart.c, rtl22xx/startup/bspstart.c,
shared/abort/abort.c, shared/abort/simple_abort.c,
shared/irq/irq_init.c: Code outside of cpukit should use the public
API for rtems_interrupt_disable/rtems_interrupt_enable. By bypassing
the public API and directly accessing _CPU_ISR_Disable and
_CPU_ISR_Enable, they were bypassing the compiler memory barrier
directive which could lead to problems. This patch also changes the
type of the variable passed into these routines and addresses minor
style issues.
* shared/abort/abort.c, shared/abort/simple_abort.c: Remove incorrect
and unneccessary prototype of printk.
* shared/abort/simple_abort.c: Shrink the memory requirements. Joel
reformatted for style.
* shared/abort/abort.c, shared/abort/simple_abort.c: New files.
