2017-03-08 | arm: Remove legacy execption support | Sebastian Huber | 1 | -145/+0 | |
2014-11-20 | ARM removed shared/abort from several ARM BSPs | Alan Cudmore | 1 | -28/+1 | |
2014-10-09 | arm/shared/abort/abort.c: Fix warnings and clean up | Joel Sherrill | 1 | -17/+28 | |
2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | 1 | -1/+1 | |
2013-07-16 | bsps: Use rtems_task_self() | Sebastian Huber | 1 | -1/+1 | |
2011-02-11 | 2011-02-11 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -1/+1 | |
* shared/abort/abort.c, shared/abort/simple_abort.c: Use "__asm__" instead of "asm" for improved c99-compliance. | |||||
2010-01-12 | add support for lpc32xx | Thomas Doerfler | 1 | -6/+8 | |
2009-11-29 | Whitespace removal. | Ralf Corsepius | 1 | -7/+7 | |
2007-09-12 | 2007-09-12 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 1 | -6/+4 | |
PR 1257/bsps * csb336/network/lan91c11x.c, csb337/startup/bspstart.c, edb7312/irq/irq.c, gba/irq/irq.c, gba/irq/irq_init.c, gp32/startup/bspstart.c, rtl22xx/startup/bspstart.c, shared/abort/abort.c, shared/abort/simple_abort.c, shared/irq/irq_init.c: Code outside of cpukit should use the public API for rtems_interrupt_disable/rtems_interrupt_enable. By bypassing the public API and directly accessing _CPU_ISR_Disable and _CPU_ISR_Enable, they were bypassing the compiler memory barrier directive which could lead to problems. This patch also changes the type of the variable passed into these routines and addresses minor style issues. | |||||
2007-09-08 | 2007-09-08 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 1 | -3/+3 | |
* shared/abort/abort.c, shared/abort/simple_abort.c: Remove incorrect and unneccessary prototype of printk. | |||||
2007-05-15 | 2007-05-15 Ray Xu <rayx@gmail.com> | Joel Sherrill | 1 | -0/+161 | |
* shared/abort/abort.c, shared/abort/simple_abort.c: New files. |
