do
echo $b
# echo $g
-i $b
done
Fix typo.
closes 2345.
Close #2303.
This section can be use to provide a cache coherent memory area via
rtems_cache_coherent_add_area().
These flags are obsolete with the EABI based ARM tool chain.
Provide a file per BSP to list tests that do not build for a BSP. This change
removes the BSP_SMALL_MEMORY hack from the code. That hack was a
mistake.
Provide configuration files for each BSP with tests that cannot build.
This is necessary to add tests that use the cache manager. For example
to get better estimates of worst-case timings.
Conflicts:
Replace the "NIRVANA" region with the more verbose "UNEXPECTED_SECTIONS"
region. Move the region definition into the "linkcmds.base" files.
Many files had an extra blank line in the license text
found in the file header. This patch removes that line.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.rtems.com/license/LICENSE.
The script that did this also turned off execute permission
when it was turned on incorrectly.
PR 1953/bsps
* console/uart.c: Do not use /dev/console in libchip configuration
table. Shared driver framework selects device to use as /dev/console.
PR 1917/bsps
* Makefile.am, console/uart.c: Modifications to add dynamic tables for
libchip serial drivers.
* make/custom/rtl22xx_t.cfg: Remove USE_THUMB (Violates *.cfg
conventions, unused).
* startup/bspreset.c:
* make/custom/rtl22xx_t.cfg: Now compiles.
* startup/linkcmds, start/start.S: Use linker command base file.
* make/custom/rtl22xx_t.cfg: Workaround for GCC bug 38644.
* include/bsp.h: Add BSP_SMALL_MEMORY.
* Makefile.am, preinstall.am: Added generic interrupt support modules.
* include/bsp.h: Define BSP_FEATURE_IRQ_EXTENSION.
* startup/bspstart.c, network/network.c: Interrupt support changes.
* console/uart.c: Fixed warnings.
* csb336/make/custom/csb336.cfg,
csb337/make/custom/csb337.cfg, edb7312/make/custom/edb7312.cfg,
gba/make/custom/gba.cfg, gdbarmsim/make/custom/arm920.cfg,
gp32/make/custom/gp32.cfg, gumstix/make/custom/gumstix.cfg,
lpc32xx/make/custom/lpc32xx_phycore.cfg, nds/make/custom/nds.cfg,
rtl22xx/make/custom/rtl22xx.cfg, smdk2410/make/custom/smdk2410.cfg:
Use VFP floating point model.
