* include/bsp.h: Eliminate BSPs defining NUMBER_OF_TERMIOS_PORTS.
Should be automatically handled by confdefs.h or the application.
PR 1380/bsps
* include/bsp.h: Switch to English comments.
* Makefile.am, preinstall.am: Use shared tm27.h stub.
* include/tm27.h: Removed.
* include/bsp.h: Remove define of BSP_ZERO_WORKSPACE_AUTOMATICALLY.
* include/bsp.h, startup/bspstart.c: Eliminate copies of the
Configuration Table. Use the RTEMS provided accessor macros to obtain
configuration fields.
* include/bsp.h, startup/bspstart.c: Move interrupt_stack_size field
from CPU Table to Configuration Table. Eliminate CPU Table from all
ports. Delete references to CPU Table in all forms.
* Makefile.am, include/bsp.h, startup/bspstart.c: Moved most of the
remaining CPU Table fields to the Configuration Table. This included
pretasking_hook, predriver_hook, postdriver_hook, idle_task,
do_zero_of_workspace, extra_mpci_receive_server_stack,
stack_allocate_hook, and stack_free_hook. As a side-effect of this
effort some multiprocessing code was made conditional and some style
clean up occurred.
* README, times, console/lpc22xx_uart.h, console/uart.c, include/bsp.h,
start/start.S, startup/bspstart.c, startup/exit.c, startup/linkcmds:
Update BSP to address changes between 4.7 and CVS head as well as to
address comments from Ralf and Joel.
* include/tm27.h, startup/bspstart.c, startup/exit.c,
startup/linkcmds: New (Initial submission).
* Makefile.am, README, bsp_specs, configure.ac,
network/network.c: New (Initial submission).
