Many files had an extra blank line in the license text
found in the file header. This patch removes that line.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.rtems.com/license/LICENSE.
The script that did this also turned off execute permission
when it was turned on incorrectly.
PR 1953/bsps
* console/uart.c: Do not use /dev/console in libchip configuration
table. Shared driver framework selects device to use as /dev/console.
PR 1917/bsps
* Makefile.am, console/uart.c: Modifications to add dynamic tables for
libchip serial drivers.
* Makefile.am, preinstall.am: Added generic interrupt support modules.
* include/bsp.h: Define BSP_FEATURE_IRQ_EXTENSION.
* startup/bspstart.c, network/network.c: Interrupt support changes.
* console/uart.c: Fixed warnings.
* Makefile.am, configure.ac, console/uart.c, startup/bspstart.c: Use
standardized bsp_cleanup() which can optionally print a message, poll
for user to press key, and call bsp_reset(). Using this eliminates
the various bsp_cleanup() implementations which had their own
implementation and variety of string constants.
* startup/bspclean.c: Removed.
* Makefile.am, console/lpc22xx_uart.h: Remove warnings, cleanup and do
not build SPARC code accidentally referenced in Makefile.am.
* console/uart.c, startup/bspclean.c, startup/bspstart.c: Remove debug
print methods that are redundant with prntk and replace their usage
with printk.
* README, times, console/lpc22xx_uart.h, console/uart.c, include/bsp.h,
start/start.S, startup/bspstart.c, startup/exit.c, startup/linkcmds:
Update BSP to address changes between 4.7 and CVS head as well as to
address comments from Ralf and Joel.
* Makefile.am, README, bsp_specs, configure.ac,
network/network.c: New (Initial submission).
