Close #3250.
Close #4081.
Update #4267.
Use the standard ARMv7-M systick module for the ARMv7-M CPU counter
instead of DWT counter since the DWT counter is affected by power saving
states.
Use an inline function for _CPU_Counter_difference() for all ARM BSPs.
Update #3456.
Add rtems_counter_frequency() API function. Use it to initialize the
counter value converter via the new system initialization step
(RTEMS_SYSINIT_CPU_COUNTER). This decouples the counter implementation
and the counter converter. It avoids an unnecessary pull in of the
64-bit integer division from libgcc.
Update #3456.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #2408.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
Update #3285.
* bsps/shared/cache
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
This is necessary to pick up mandatory flags provided by the build
system.
Update #3254.
Update #3254.
EXTRA_DIST += foobar
in fragments.
Update #3254.
Update #3254.
Update #3254.
header file.
Update #3254.
maintain.
Update #3254.
Update #3239.
Update #2408.
Update #2408.
This is necessary to add tests that use the cache manager. For example
to get better estimates of worst-case timings.
PR 1917/bsps
* Makefile.am, console/uart.c: Modifications to add dynamic tables for
libchip serial drivers.
* Makefile.am, preinstall.am: Added generic interrupt support modules.
* include/bsp.h: Define BSP_FEATURE_IRQ_EXTENSION.
* startup/bspstart.c, network/network.c: Interrupt support changes.
* console/uart.c: Fixed warnings.
* Makefile.am, preinstall.am: Use shared tm27.h stub.
* include/tm27.h: Removed.
