* Makefile.am, console/lpc22xx_uart.h: Remove warnings, cleanup and do
not build SPARC code accidentally referenced in Makefile.am.
* console/uart.c, startup/bspclean.c, startup/bspstart.c: Remove debug
print methods that are redundant with prntk and replace their usage
with printk.
* Makefile.am: Tinkering to reduce .text size of minimum executable
from ~64K to ~47K.
* Renamed startup/exit.c to startup/bspclean.c
* startup/bspclean.c: New file.
* startup/exit.c: Removed.
* README, times, console/lpc22xx_uart.h, console/uart.c, include/bsp.h,
start/start.S, startup/bspstart.c, startup/exit.c, startup/linkcmds:
Update BSP to address changes between 4.7 and CVS head as well as to
address comments from Ralf and Joel.
* Makefile.am: Remove reference to ../../shared/main.c.
* times: New (Initial submission).
* start/start.S: New (Initial submission).
* include/tm27.h, startup/bspstart.c, startup/exit.c,
startup/linkcmds: New (Initial submission).
* Makefile.am: Include preinstall.am
* bsp_specs: Sync with modern GCC.
* Makefile.am, README, bsp_specs, configure.ac,
network/network.c: New (Initial submission).
