counter
timer interrupt was hard coded to 10 ms per tick.
Fix uses the setting of CONFIGURE_MICROSECONDS_PER_TICK to compute the correct start value for the counter
See for more information: http://permalink.gmane.org/gmane.os.rtems.user/22691
Fix typo.
closes 2345.
Update #2271.
This patch adds a BSP variant for the Raspberry Pi 2. You can
build both variants by configuring with the option
--enable-rtemsbsp="raspberrypi2 raspberrypi"
For the current BSP, the only change was the peripheral register base
address and the compiler options.
The raspberrypi/make/custom rules were re-factored:
raspberrypi.inc -- Common rules
raspberrypi.cfg -- Raspberry Pi 1 specific rule/optons
raspberrypi2.cfg -- Raspberry Pi 2 specific rule/options
I tested hello, ticker, unlimited, and paranoia on both the Pi (Model A+)
and Pi 2.
This was tripping a linker error in the dl0[12] tests.
closes 2247.
This section can be use to provide a cache coherent memory area via
rtems_cache_coherent_add_area().
Fix build error introduced in f535fe5311978af53635c2da8e5cb10ef9d78802.
output.
not updated.
Rename bsp_mm_config_table to arm_cp15_start_mmu_config_table and
rename bsp_mm_config_table_size to arm_cp15_start_mmu_config_table_size
to be in line with the other names in <bsp/arm-cp15-start.h>.
Define ARM_CP15_TEXT_SECTION to BSP_START_TEXT_SECTION so that the
start code is in the right section.
Delete ARMV7_MMU_DATA_READ_WRITE_SHAREABLE and move RTEMS_SMP
specific MMU attribute settings to arm-cp15.h.
Changes include reverting back to setting all page-table section entries
as invalid and modify mm_config_table to apply the correct memory attributes
for raspbberypi memory sections at startup. The newly added entry at mm_config_table
maps raspberrypi GPIO and other registers found at raspberrypi.h
Add support for MMU initialization for RaspberryPi. Introduce new shared
MMU configuration table that can be used by other BSPs that call the
arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache function.
Demonstrate the use of the generic table with RaspberryPi.
