BSPs.
The original ARM architecture wide cache_.h is changed to dummy version
for targets not implementing/enablig cache at all.
The ARM targets equipped by cache should include
appropriate implementation.
Next options are available for now
c/src/lib/libbsp/arm/shared/armv467ar-basic-cache/cache_.h
basic ARM cache integrated on the CPU core directly
which requires only CP15 oparations
c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h
support for case where ARM L2C-310 cache controller
is used. It is accessible as mmaped peripheral.
c/src/lib/libbsp/arm/shared/armv7m/include/cache_.h
Cortex-M specific cache support
Updates #2782
Updates #2783
Fix build error introduced in f535fe5311978af53635c2da8e5cb10ef9d78802.
not updated.
Add support for MMU initialization for RaspberryPi. Introduce new shared
MMU configuration table that can be used by other BSPs that call the
arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache function.
Demonstrate the use of the generic table with RaspberryPi.
