path: root/c/src/lib/libbsp/arm/raspberrypi/misc (unfollow)
2016-10-02arm/raspberrypi: ensure that correct RPI_PERIPHERAL_BASE is provided by ↵Pavel Pisa1-0/+1
raspberrypi.h If the raspberrypi.h has been included without preceding inclussion of bsp.h then BSP_IS_RPI2 has not been set for Raspberry Pi 2 BSP variant and bad things happen later. The patch includes bspopts.h by raspberrypi.h and even includes bsp.h in critical peripherals support. Updates #2783
2014-09-16Use correct prototype of benchmark_timer_read()Joel Sherrill1-2/+2
This change starts with removing the effectively empty file timerdrv.h. The prototypes for benchmark_timer_XXX() were in btimer.h which was not universally used. Thus every use of timerdrv.h had to be changed to btimer.h. Then the prototypes for benchmark_timer_read() had to be adjusted to return benchmark_timer_t rather than int or uint32_t. I took this opportunity to also correct the file headers to separate the copyright from the file description comments which is needed to ensure the copyright isn't propagated into Doxygen output.
2014-03-21Change all references of rtems.com to rtems.org.Chris Johns1-1/+1
2013-03-24bsp/raspberrypi: New BSPAlan Cudmore1-0/+49
