* | arm/raspberrypi: ensure that correct RPI_PERIPHERAL_BASE is provided by ↵ | Pavel Pisa | 2016-10-02 | 1 | -0/+1 |
| | | | | | | | | | | | | | raspberrypi.h If the raspberrypi.h has been included without preceding inclussion of bsp.h then BSP_IS_RPI2 has not been set for Raspberry Pi 2 BSP variant and bad things happen later. The patch includes bspopts.h by raspberrypi.h and even includes bsp.h in critical peripherals support. Updates #2783 | ||||
* | preliminary Raspberry Pi Model 2 support | Alan Cudmore | 2015-03-16 | 1 | -6/+20 |
| | | | | | | | | | | | | | | | | | This patch adds a BSP variant for the Raspberry Pi 2. You can build both variants by configuring with the option --enable-rtemsbsp="raspberrypi2 raspberrypi" For the current BSP, the only change was the peripheral register base address and the compiler options. The raspberrypi/make/custom rules were re-factored: raspberrypi.inc -- Common rules raspberrypi.cfg -- Raspberry Pi 1 specific rule/optons raspberrypi2.cfg -- Raspberry Pi 2 specific rule/options I tested hello, ticker, unlimited, and paranoia on both the Pi (Model A+) and Pi 2. | ||||
* | raspberrypi doxygen refactoring | Daniel Ramirez | 2013-11-27 | 1 | -4/+10 |
* | bsp/raspberrypi: New BSP | Alan Cudmore | 2013-03-24 | 1 | -0/+194 |
