This support is required when newer firmware is used on
Raspberry Pi 2 boards.
Updates #2783
BSPs.
The original ARM architecture wide cache_.h is changed to dummy version
for targets not implementing/enablig cache at all.
The ARM targets equipped by cache should include
appropriate implementation.
Next options are available for now
c/src/lib/libbsp/arm/shared/armv467ar-basic-cache/cache_.h
basic ARM cache integrated on the CPU core directly
which requires only CP15 oparations
c/src/lib/libbsp/arm/shared/arm-l2c-310/cache_.h
support for case where ARM L2C-310 cache controller
is used. It is accessible as mmaped peripheral.
c/src/lib/libbsp/arm/shared/armv7m/include/cache_.h
Cortex-M specific cache support
Updates #2782
Updates #2783
This was tripping a linker error in the dl0[12] tests.
closes 2247.
Fix build error introduced in f535fe5311978af53635c2da8e5cb10ef9d78802.
Add support for MMU initialization for RaspberryPi. Introduce new shared
MMU configuration table that can be used by other BSPs that call the
arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache function.
Demonstrate the use of the generic table with RaspberryPi.
PR 1951/bsps
* Makefile.am, console/console-config.c: Update due to API changes.
* 0001-Fixed-interrupt-handling-for-ARMv7M.patch,
0002-Fixed-system-handler-priority-register-access.patch,
0003-Disable-priority_mask-unused-for-NVIC.patch, 0004-Typo.patch,
0005-Evil-hack-for-BASEPRI-BASEPRI_MAX.patch,
0006-Evil-hack-to-increase-the-RAM-size.patch, bsp_specs, ChangeLog,
clock/clock-config.c, configure.ac, console/console-config.c,
console/uart.c, .cvsignore, include/bsp.h, include/.cvsignore,
include/irq.h, include/lm3s69xx.h, include/uart.h, irq/irq.c,
make/custom/lm3s6965.cfg, make/custom/lm3s69xx.inc, Makefile.am,
README, start/start.S, startup/bspreset.c, startup/bspstart.c,
startup/bspstarthook.c, startup/linkcmds.lm3s6965, timer/timer.c: New
files.
Sebastian Huber <sebastian.huber@embedded-brains.de>
* misc/nand-mlc-erase-block-safe.c: New file
* Makefile.am: Reflect change from above.
* misc/nand-mlc-write-blocks.c: Use lpc32xx_mlc_erase_block_safe_3().
* include/nand-mlc.h: Bad block handling.
* Makefile.am: Fix broken path to cache_.h.
* Makefile.am: Fix broken path to clockdrv_shell.h.
* Makefile.am, preinstall.am: Cache manager changes.
* Makefile.am, preinstall.am: Install new header files.
* include/bsp.h, include/emc.h, include/lpc32xx.h, misc/emc.c: Update
for API changes.
* include/lpc32xx.h: Added I2S module.
* Makefile.am, bsp_specs, preinstall.am, startup/bspstarthooks.c,
startup/linkcmds.lpc32xx, startup/linkcmds.lpc32xx_mzx,
startup/linkcmds.lpc32xx_mzx_stage_1,
startup/linkcmds.lpc32xx_mzx_stage_2,
startup/linkcmds.lpc32xx_phycore: Update due to linker command file
changes.
* include/tm27.h: New file.
* Makefile.am, preinstall.am: Reflect change above.
* include/bsp.h: Fixed lpc32xx_micro_seconds_delay().
* misc/timer.c: Support for timer tests.
* misc/mmu.c: New file.
* Makefile.am: Reflect change above.
* configure.ac, include/bspopts.h.in, include/irq.h,
include/lpc32xx.h, include/mmu.h, misc/emc.c, misc/restart.c,
startup/bspstarthooks.c: Changes throughout.
* make/custom/lpc32xx_mzx_boot_int.cfg,
startup/linkcmds.lpc32xx_mzx_boot_int: Removed files.
* include/boot.h, include/emc.h, include/i2c.h, include/nand-mlc.h,
make/custom/lpc32xx_mzx.cfg, make/custom/lpc32xx_mzx_stage_1.cfg,
make/custom/lpc32xx_mzx_stage_2.cfg, misc/boot.c, misc/emc.c,
misc/i2c.c, misc/nand-mlc.c, misc/nand-mlc-read-blocks.c,
misc/nand-mlc-write-blocks.c, misc/restart.c,
startup/linkcmds.lpc32xx_mzx_stage_2: New files.
* configure.ac, Makefile.am, preinstall.am: Reflect changes above.
* include/bsp.h, include/lpc32xx.h, irq/irq.c, rtc/rtc-config.c,
startup/bspstart.c, startup/bspstarthooks.c,
startup/linkcmds.lpc32xx_phycore: Changes throughout.
* make/custom/lpc32xx.inc, make/custom/lpc32xx_mzx_boot_int.cfg,
startup/linkcmds.lpc32xx_mzx_boot_int: New files.
* Makefile.am, configure.ac, preinstall.am, include/bsp.h,
include/bspopts.h.in, include/lpc32xx.h, irq/irq.c,
make/custom/lpc32xx_phycore.cfg, startup/bspstart.c,
* include/irq-config.h: Removed file.
* irq/irq.c: Removed superfluous parameter checks.
* configure.ac: Add RTEMS_BSP_LINKCMDS.
* make/custom/lpc24xx.inc: Remove LDFLAGS.
* make/custom/lpc24xx_ea.cfg: Remove LPC24XX_LINKCMDS.
* make/custom/lpc24xx_ncs_ram.cfg: Remove LPC24XX_LINKCMDS.
* make/custom/lpc24xx_ncs_rom_ext.cfg: Remove LPC24XX_LINKCMDS.
* make/custom/lpc24xx_ncs_rom_int.cfg: Remove LPC24XX_LINKCMDS.
* startup/linkcmds: Remove.
* Makefile.am: Rework linkcmds handling.
* Makefile.am, preinstall.am, include/bsp.h: Rename BSP specific idle
thread to bsp_idle_thread.
* misc/bspidle.c: New file.
* include/idle.h, misc/idle.c: Removed.
* Makefile.am, configure.ac, preinstall.am: Added BSP variants.
* console/console-config.c, clock/clock-config.c, ssp/ssp.c: Fixed
register settings. Cleanup.
* include/bsp.h: Added network defines and functions.
* include/lpc24xx.h: Added AHB and EMC defines. Fixed Ethernet status
sizes.
* include/system-clocks.h, misc/system-clocks.c: Added micro seconds
delay function that uses Timer 1. Changed PLL setup.
* network/network.c, startup/bspreset.c, startup/linkcmds.lpc2478,
startup/linkcmds.lpc2478_ncs, startup/linkcmds.lpc2478_ncs_ram: New
files.
* startup/bspstart.c: Added EMC initialization. Changes for ROM boot.
* Makefile.am: Fix breakage introduced in 2009-02-13 changes.
* Makefile.am, preinstall.am: Use stub tm27.h.
* Makefile.am, preinstall.am: Add timer driver stub.
* clock/clock-config.c: include "../../../shared/clockdrv_shell.h".
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
