* startup/bspgetworkarea.c: Removed file.
* Makefile.am, bsp_specs, start/start.S, startup/bspstart.c,
libnds/include/nds/jtypes.h, libnds/source/arm9/gurumeditation.c,
libnds/source/common/interruptDispatcher.S,
libnds/source/common/interrupts.c, startup/linkcmds: Use linker
command base file.
* make/dswifi/arm9/makefile: Workaround for GCC bug 38644.
* make/custom/nds.cfg, Makefile.am, dswifi/arm7/makefile: Use VFP
floating point model.
* csb336/make/custom/csb336.cfg,
csb337/make/custom/csb337.cfg, edb7312/make/custom/edb7312.cfg,
gba/make/custom/gba.cfg, gdbarmsim/make/custom/arm920.cfg,
gp32/make/custom/gp32.cfg, gumstix/make/custom/gumstix.cfg,
lpc32xx/make/custom/lpc32xx_phycore.cfg, nds/make/custom/nds.cfg,
rtl22xx/make/custom/rtl22xx.cfg, smdk2410/make/custom/smdk2410.cfg:
Use VFP floating point model.
* console/console.c: Fix warnings.
* startup/bspstart.c: Fix warning.
* start/start.S: Verify boot_card() is passed a NULL.
* console/console.c: Let nds_getch return "int". Remove casts.
* block/block.c: Adjust prototype mismatches.
* Makefile.am: Remove -Dcaddr_t=uint32_t.
* dswifi/arm9/source/wifi_arm9.c: Add missing prototypes.
* ndstool/source/ndsextract.cpp: Add missing const's.
* console/console.c (nds_write): Adjust prototype.
* dswifi/arm7/source/wifi_arm7.c, dswifi/arm7/source/wifi_arm7.h,
dswifi/arm9/source/wifi_arm9.c, libnds/include/nds/arm7/audio.h,
libnds/include/nds/arm7/clock.h, libnds/include/nds/arm7/serial.h,
libnds/include/nds/arm7/touch.h, libnds/source/arm7/clock.c,
libnds/source/arm7/touch.c, rtc/rtc.c: Eliminate various warnings.
* bin2s: Remove.
* bin2s.c: Remove CVS-$Log's.
* libnds/include/nds/arm9/exceptions.h,
libnds/include/nds/arm9/image.h,
libnds/include/nds/arm9/input.h,
libnds/include/nds/arm9/math.h,
libnds/include/nds/arm9/pcx.h,
libnds/include/nds/arm9/rumble.h,
libnds/include/nds/arm9/sound.h,
libnds/include/nds/arm9/trig_lut.h,
libnds/source/arm9/dcache.S,
libnds/source/arm9/exceptionHandler.S,
libnds/source/arm9/exceptions.c,
libnds/source/arm9/image.c,
libnds/source/arm9/keys.c,
libnds/source/arm9/pcx.c,
libnds/source/arm9/rumble.c,
libnds/source/arm9/sound.c,
libnds/source/arm9/system.c,
libnds/source/arm9/touch.c,
libnds/source/common/biosCalls.S,
libnds/source/common/gbfs.c,
libnds/source/common/interrupts.c:
Remove CVS-$Log's.
* make/custom/nds.cfg: Remove RTEMS_BSP_FAMILY.
* make/custom/nds.cfg: New (relocated from /make/custom).
* configure.ac: Remove RTEMS_BSP_BOOTCARD_OPTIONS.
* nds/fb/fb.c: took off get_screen_info() and set_screen_info() extern
references
* fb/fb.c: function calls renamed; defined references to the extern
functions
* fb/fb.h: Removed.
* Makefile.am: Reflect removal.
* preinstall.am: Regenerated.
* fb/fb.c: different structures defined in rtems/fb.h that were used in
here so changes were needed
* Makefile.am, preinstall.am, fb/fb.c: Install nds specific .h files
into nds subdirectory.
* fb/fb.c: changed the references to mw_fb.h into fb.h
* configure.ac: Rename BSP_BOOTCARD_OPTIONS to
RTEMS_BSP_BOOTCARD_OPTIONS. Add RTEMS_BSP_CLEANUP_OPTIONS so all BSPs
have the same options.
* startup/bspgetworkarea.c: Switch from ssize_t to uintptr_t for
bsp_get_work_area() since the work area is larger than a single
allocatable object.
* start/start.S: Checked call to boot_card.
* ndstool/include/banner.h, ndstool/include/header.h,
ndstool/include/ndstree.h, ndstool/source/banner.cpp,
ndstool/source/header.cpp, ndstool/source/ndscreate.cpp,
ndstool/source/ndstool.cpp, ndstool/source/passme.cpp: Remove
warnings for deprecated character conversions.
* start/start.S: Update for boot_card command line change.
* Makefile.am: Add -D__BSD_VISIBLE to wifi_rel_CPPFLAGS.
* bsp_specs: Remove -Qy from *link.
* bsp_specs: Move -e start from *link to *startfile to avoid warning
for undefined entry symbol when linking relocatables with binutils
2.19.
* Makefile.am, preinstall.am: Use shared tm27.h stub.
* include/tm27.h: Removed.
* startup/bspgetworkarea.c: Change size_t to ssize_t on
bsp_get_work_area(). On 16-bit architectures, size_t can be 16-bits
which would limit the work area to 64K.
* clock/clock.c: include "../../../shared/clockdrv_shell.h".
* Makefile.am: Eliminate bsp.am. Build startup files as side-effect
of building libbspstart.a, using automake-rules.
* Makefile.am: Eliminate *_SOURCES.
* Makefile.am: Move noinst_LIBRARIES = libbsp.a before its
components.
* Makefile.am: Cleanup ../../shared/include/bootcard.h handling.
* configure.ac: Make letting boot_card() handle work area allocation
mandatory. Rename RTEMS_BSP_BOOTCARD_HANDLES_RAM_ALLOCATION to
* startup/bspreset.c: New file.
