These files were left after running the script in the previous patch.
Fix typo.
closes 2345.
Update #2271.
This section can be use to provide a cache coherent memory area via
rtems_cache_coherent_add_area().
This patch eliminates most of the warnings in this BSP but attempts
very little clean up. This BSP includes copies of a lot of code
from free NDS libraries and modifications should be kept to a minimum.
These flags are obsolete with the EABI based ARM tool chain.
not updated.
This was necessary to enable all tests to link.
This is necessary to add tests that use the cache manager. For example
to get better estimates of worst-case timings.
Add reserved system events RTEMS_EVENT_SYSTEM_NETWORK_SBWAIT and
RTEMS_EVENT_SYSTEM_NETWORK_SOSLEEP.
Add and use rtems_bsdnet_event_send().
Conflicts:
Add nanoseconds_per_tick to rtems_configuration_table. This value will
be derived from the microseconds_per_tick value. This avoids some
calculations at run-time.
Replace the "NIRVANA" region with the more verbose "UNEXPECTED_SECTIONS"
region. Move the region definition into the "linkcmds.base" files.
These modifications were required by hand after running the script.
In some cases, the file names did not match patterns. In others,
the format of the file did not match any common patterns.
* startup/linkcmds: Fixed instruction cache size.
* start/start.S: Fixed code section.
* irq/irq.c: Removed printk() before the interrupt initialization
because it somehow destroys the interrupt context.
* make/custom/nds.cfg: Enable Thumb interwork.
* startup/bspstart.c: Set default exception handler.
* Makefile.am: Fix broken path to clockdrv_shell.h.
* dswifi/common/source/spinlock.h:
Use "__asm__" instead of "__asm" for improved c99-compliance.
* console/console.c, dswifi/arm9/source/wifi_arm9.c, tools/bin2s.c:
* timer/timer.c: Include <rtems/btimer.h>.
* gba/clock/clockdrv.c, gba/console/conio.c, gba/console/console.c,
gba/console/defaultfont.h, gba/include/arm_mode_bits.h,
gba/include/asm_macros.h, gba/include/bsp.h, gba/include/conio.h,
gba/include/gba.h, gba/include/gba_registers.h, gba/irq/irq.c,
gba/irq/irq.h, gba/startup/bspstart.c, gba/timer/timer.c,
gp32/include/bsp.h, gp32/startup/bspreset.c, gp32/startup/bspstart.c,
nds/tools/runtest, shared/comm/uart.c, shared/comm/uart.h,
smdk2410/include/bsp.h: Fix typo where license said
found in found in.
* startup/bspgetworkarea.c: Removed file.
* Makefile.am, bsp_specs, start/start.S, startup/bspstart.c,
libnds/include/nds/jtypes.h, libnds/source/arm9/gurumeditation.c,
libnds/source/common/interruptDispatcher.S,
libnds/source/common/interrupts.c, startup/linkcmds: Use linker
command base file.
* make/dswifi/arm9/makefile: Workaround for GCC bug 38644.
* make/custom/nds.cfg, Makefile.am, dswifi/arm7/makefile: Use VFP
floating point model.
* csb336/make/custom/csb336.cfg,
csb337/make/custom/csb337.cfg, edb7312/make/custom/edb7312.cfg,
gba/make/custom/gba.cfg, gdbarmsim/make/custom/arm920.cfg,
gp32/make/custom/gp32.cfg, gumstix/make/custom/gumstix.cfg,
lpc32xx/make/custom/lpc32xx_phycore.cfg, nds/make/custom/nds.cfg,
rtl22xx/make/custom/rtl22xx.cfg, smdk2410/make/custom/smdk2410.cfg:
Use VFP floating point model.
