* | bsps: Delete superfluous bsp_pretasking_hook() | Sebastian Huber | 2015-12-10 | 1 | -1/+0 |
| | | | | | | Use the bsp_predriver_hook() instead. Update #2408. | ||||
* | Multiple bsp_specs: Change *(old_endfile) to %(old_endfile) | Joel Sherrill | 2015-05-21 | 1 | -1/+1 |
| | | | | | | Fix typo. closes 2345. | ||||
* | bsps: Convert clock drivers to use a timecounter | Alexander Krutwig | 2015-05-20 | 1 | -0/+2 |
| | | | | Update #2271. | ||||
* | Add fsscandir01 variants as needed to more BSPs testsuite configuration | Joel Sherrill | 2015-03-06 | 1 | -0/+1 |
* | Fix a number of minor Doxygen formatting issues | Joel Sherrill | 2015-03-06 | 1 | -1/+1 |
* | bsp/lpc32xx: Fix memory map | Sebastian Huber | 2014-12-15 | 1 | -1/+1 |
| | | | | | | Fixes bug introduced with f0c564c5ae36da20b1543ae9db9e8fe9644a81c8. close #2218 | ||||
* | Update bug report URL | Sebastian Huber | 2014-12-05 | 1 | -1/+1 |
* | bsps/arm: Add .nocache section | Sebastian Huber | 2014-11-27 | 4 | -0/+8 |
| | | | | | This section can be use to provide a cache coherent memory area via rtems_cache_coherent_add_area(). | ||||
* | bsp/lpc32xx: Fix warning | Sebastian Huber | 2014-10-10 | 1 | -1/+1 |
* | libchip/serial: Add alternative NS16550 driver | Sebastian Huber | 2014-10-07 | 5 | -239/+296 |
| | | | | Use the Termios device API. | ||||
* | bsps: Fix build error | Sebastian Huber | 2014-09-18 | 2 | -5/+0 |
| | | | | Fix build error introduced in f535fe5311978af53635c2da8e5cb10ef9d78802. | ||||
* | Use correct prototype of benchmark_timer_read() | Joel Sherrill | 2014-09-16 | 1 | -2/+1 |
| | | | | | | | | | | | | | | This change starts with removing the effectively empty file timerdrv.h. The prototypes for benchmark_timer_XXX() were in btimer.h which was not universally used. Thus every use of timerdrv.h had to be changed to btimer.h. Then the prototypes for benchmark_timer_read() had to be adjusted to return benchmark_timer_t rather than int or uint32_t. I took this opportunity to also correct the file headers to separate the copyright from the file description comments which is needed to ensure the copyright isn't propagated into Doxygen output. | ||||
* | bsps/arm: Do not build unused file | Sebastian Huber | 2014-09-08 | 1 | -1/+0 |
* | Regenerate all preinstall.am files. | Chris Johns | 2014-08-29 | 1 | -7/+7 |
| | | | | | With this patch the preinstall.am files are in a set order and not dependent on now perl implements a hash. | ||||
* | Regenerate all preinstall.am files. | Joel Sherrill | 2014-08-28 | 1 | -3/+3 |
| | | | | | Apparently, at some point automake output changed and these were not updated. | ||||
* | arm: Add tests which fail to build with C++ enabled. | Chris Johns | 2014-08-28 | 1 | -0/+2 |
* | Add More Testsuite Configuration Files and Update Existing Ones | Joel Sherrill | 2014-07-16 | 1 | -0/+3 |
| | | | | | | | The first pass at building these was without networking enabled. This pass addresses that plus accounts for some new BSPs which needed testsuite.tcfg files and BSPs which could not link tests which had been added since the first pass. | ||||
* | bsps/arm: Define ARM_CP15_TEXT_SECTION | Sebastian Huber | 2014-06-06 | 1 | -0/+2 |
| | | | | | Define ARM_CP15_TEXT_SECTION to BSP_START_TEXT_SECTION so that the start code is in the right section. | ||||
* | multiple BSPs: Remove BSP_SMALL_MEMORY | Joel Sherrill | 2014-05-06 | 1 | -4/+0 |
* | testsuite: Add a per BSP test check for tests not to build. | Chris Johns | 2014-05-05 | 1 | -0/+17 |
| | | | | | | | | Provide a file per BSP to list tests that do not build for a BSP. This change removes the BSP_SMALL_MEMORY hack from the code. That hack was a mistake. Provide configuration files for each BSP with tests that cannot build. | ||||
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 29 | -29/+29 |
* | bsp/lpc32xx: Add arm-errata.h and arm-release-id.h | Ralf Kirchner | 2014-03-13 | 2 | -0/+10 |
* | score: Add CPU counter support | Sebastian Huber | 2014-02-14 | 2 | -4/+10 |
| | | | | | | | | | Add a CPU counter interface to allow access to a free-running counter. It is useful to measure short time intervals. This can be used for example to enable profiling of critical low-level functions. Add two busy wait functions rtems_counter_delay_ticks() and rtems_counter_delay_nanoseconds() implemented via the CPU counter. | ||||
* | doxygen: refactored doxygen in libbsp/arm/lpc32xx | Daniel Ramirez | 2013-11-29 | 20 | -23/+34 |
| | | | | | | | | This patch refactors a lot of the existing doxygen within libbsp/arm/lpc32xx. Much of this refactoring was just renaming of existing groups to conform to a more consistent naming structure. With the addition of a doxygen header for tm27.h, all files within lpc32xx belong to doxygen group now. lpc32xx should be used a reference for adding doxygen to other bsps. | ||||
* | bsp/lpc32xx: Fix memory map for GPIO registers | Sebastian Huber | 2013-07-24 | 1 | -0/+2 |
* | bsps/arm: Rename function | Sebastian Huber | 2013-06-24 | 1 | -1/+1 |
| | | | | | | Rename arm_cp15_start_setup_translation_table_and_enable_mmu() in arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache() to emphasize that the cache is also enabled after this operation. | ||||
* | bsps/arm: Move CP15 start initialization | Sebastian Huber | 2013-05-03 | 3 | -121/+24 |
* | bsps/arm: Add arm_cp15_set_trans*_table_entries() | Sebastian Huber | 2013-05-03 | 3 | -84/+6 |
* | bsps/arm: Add and use bsp_translation_table_base | Sebastian Huber | 2013-05-03 | 2 | -4/+2 |
* | RTEMS: Delete ChangeLog files. | Gedare Bloom | 2013-03-08 | 1 | -252/+0 |
| | | | | | | | | | This commit deletes all RTEMS ChangeLog files. These files have been abandoned since converting to git version control. The historical data may be recovered by checking out any commit before this one. Most of the contents of these ChangeLog files can also be found in the git log. Two external ChangeLog files, ChangeLog.slac and ChangeLog.zlib, remain. | ||||
* | bsp/lpc32xx: Add BSP_USB_OTG_TRANSCEIVER_VBUS | Sebastian Huber | 2013-02-12 | 1 | -0/+3 |
* | libchip/serial: Add const qualifier | Sebastian Huber | 2013-02-11 | 2 | -2/+2 |
* | bsp/lpc32xx: Bypass the IrDA modem for UART6 | Sebastian Huber | 2013-01-11 | 1 | -3/+6 |
* | bsp/lpc32xx: System reset after fatal conditions | Sebastian Huber | 2013-01-07 | 1 | -1/+1 |
* | arm: Rename inline functions | Sebastian Huber | 2013-01-07 | 1 | -2/+2 |
| | | | | | Rename arm_status_irq_enable() to _ARMV4_Status_irq_enable() and arm_status_restore() to _ARMV4_Status_restore(). | ||||
* | arm: Rename arm_exc_interrupt() | Sebastian Huber | 2013-01-07 | 1 | -1/+1 |
| | | | | Rename arm_exc_interrupt() to _ARMV4_Exception_interrupt(). | ||||
* | arm: Move prototypes to new file | Sebastian Huber | 2013-01-07 | 1 | -0/+2 |
| | | | | | | Move bsp_interrupt_dispatch() and arm_exc_interrupt() prototypes to new file <rtems/score/armv4.h> since they have nothing to do with the CPU port. | ||||
* | bsps/arm: Add interface down support | Sebastian Huber | 2012-12-18 | 1 | -0/+5 |
* | bsp/lpc32xx: Add UART_CLKMODE settings | Sebastian Huber | 2012-12-18 | 2 | -0/+4 |
* | bsp/lpc32xx: Configure U4_TX pin for UART 4 | Sebastian Huber | 2012-12-18 | 1 | -0/+8 |
* | bsp/lpc32xx: Fix function prototype | Sebastian Huber | 2012-12-18 | 1 | -2/+2 |
* | bsp/lpc32xx: Add idle thread body | Sebastian Huber | 2012-12-18 | 3 | -0/+39 |
* | bsp/lpc32xx: Fix console baud configuration | Sebastian Huber | 2012-12-13 | 3 | -48/+64 |
* | bsps: Interrupt initialization error is fatal | Sebastian Huber | 2012-11-15 | 1 | -3/+1 |
* | score: Add RTEMS_FATAL_SOURCE_EXIT | Sebastian Huber | 2012-11-15 | 1 | -6/+7 |
| | | | | | | | Include <bsp/default-initial-extension.h> in all BSPs. Call rtems_fatal() with RTEMS_FATAL_SOURCE_EXIT as source and the exit() status code as fatal code in every bsp_cleanup(). Move previous bsp_cleanup() code into bsp_fatal_extension(). | ||||
* | bsps/arm: Add BSP_USB_OTG_TRANSCEIVER_I2C_ADDR | Sebastian Huber | 2012-10-12 | 1 | -0/+3 |
* | bsps/arm: Add LPC_DMA_CHANNEL_COUNT | Sebastian Huber | 2012-09-28 | 1 | -0/+3 |
* | bsp/lpc32xx: Specify scratch area alignment | Sebastian Huber | 2012-08-20 | 1 | -1/+2 |
* | bsp/lpc32xx: Stop unused DDRAM_CLK | Sebastian Huber | 2012-08-20 | 1 | -1/+1 |
* | bsp/lpc32xx: Fix clock name | Sebastian Huber | 2012-08-20 | 2 | -7/+7 |
| | | | | Rename lpc32xx_dram_clk() in lpc32xx_ddram_clk() |
