The first pass at building these was without networking enabled.
This pass addresses that plus accounts for some new BSPs which
needed testsuite.tcfg files and BSPs which could not link tests
which had been added since the first pass.
Define ARM_CP15_TEXT_SECTION to BSP_START_TEXT_SECTION so that the
start code is in the right section.
Provide a file per BSP to list tests that do not build for a BSP. This change
removes the BSP_SMALL_MEMORY hack from the code. That hack was a
mistake.
Provide configuration files for each BSP with tests that cannot build.
This patch refactors a lot of the existing doxygen within libbsp/arm/lpc32xx.
Much of this refactoring was just renaming of existing groups to conform to a
more consistent naming structure. With the addition of a doxygen header for
tm27.h, all files within lpc32xx belong to doxygen group now. lpc32xx should
be used a reference for adding doxygen to other bsps.
Rename arm_cp15_start_setup_translation_table_and_enable_mmu()
in arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache()
to emphasize that the cache is also enabled after this operation.
Rename arm_status_irq_enable() to _ARMV4_Status_irq_enable() and
arm_status_restore() to _ARMV4_Status_restore().
Rename arm_exc_interrupt() to _ARMV4_Exception_interrupt().
Move bsp_interrupt_dispatch() and arm_exc_interrupt() prototypes to new
file <rtems/score/armv4.h> since they have nothing to do with the CPU
port.
Rename lpc32xx_dram_clk() in lpc32xx_ddram_clk()
Conflicts:
Replace the "NIRVANA" region with the more verbose "UNEXPECTED_SECTIONS"
region. Move the region definition into the "linkcmds.base" files.
* misc/system-clocks.c: New file.
* Makefile.am: Reflect change from above.
* include/nand-mlc.h: Fixed lpc32xx_mlc_is_bad_page().
* make/custom/lpc32xx.inc, make/custom/lpc32xx_mzx_stage_1.cfg: Flags
for EABI tool chain.
* configure.ac, include/bsp.h, include/lpc32xx.h, misc/emc.c,
misc/i2c.c, rtc/rtc-config.c, startup/bspstarthooks.c: Avoid compile
time ARM_CLK and HCLK.
* Makefile.am: Add shared/startup/bsp-start-memcpy.S
PR 1917/bsps
* Makefile.am, console/console-config.c, console/hsu.c: Modifications
to add dynamic tables for libchip serial drivers.
