line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
This patch refactors a lot of the existing doxygen within libbsp/arm/lpc32xx.
Much of this refactoring was just renaming of existing groups to conform to a
more consistent naming structure. With the addition of a doxygen header for
tm27.h, all files within lpc32xx belong to doxygen group now. lpc32xx should
be used a reference for adding doxygen to other bsps.
* include/tm27.h: New file.
* Makefile.am, preinstall.am: Reflect change above.
* include/bsp.h: Fixed lpc32xx_micro_seconds_delay().
* misc/timer.c: Support for timer tests.
