* misc/system-clocks.c: New file.
* Makefile.am: Reflect change from above.
* include/nand-mlc.h: Fixed lpc32xx_mlc_is_bad_page().
* make/custom/lpc32xx.inc, make/custom/lpc32xx_mzx_stage_1.cfg: Flags
for EABI tool chain.
* configure.ac, include/bsp.h, include/lpc32xx.h, misc/emc.c,
misc/i2c.c, rtc/rtc-config.c, startup/bspstarthooks.c: Avoid compile
time ARM_CLK and HCLK.
* make/custom/lpc32xx.inc: Workaround for GCC bug 50106.
* include/lpc32xx.h: Fixed register map for NAND MLC.
* include/boot.h: Declare lpc32xx_set_boot_block_bad().
* misc/boot.c: Define lpc32xx_set_boot_block_bad().
* include/nand-mlc.h, misc/nand-mlc-erase-block-safe.c,
misc/nand-mlc-read-blocks.c, misc/nand-mlc-write-blocks.c,
misc/nand-mlc.c: Changed bad block handling. Support for non-aligned
data. Documentation.
* Makefile.am, preinstall.am: Install new header files.
* include/bsp.h, include/emc.h, include/lpc32xx.h, misc/emc.c: Update
for API changes.
* configure.ac, include/bspopts.h.in: More options.
* include/lpc32xx.h: Added watchdog definitions.
* include/mmu.h, misc/mmu.c: Added const qualifier.
* startup/bspreset.c: Use watchdog reset.
* include/lpc32xx.h: Added I2S module.
* Makefile.am, bsp_specs, preinstall.am, startup/bspstarthooks.c,
startup/linkcmds.lpc32xx, startup/linkcmds.lpc32xx_mzx,
startup/linkcmds.lpc32xx_mzx_stage_1,
startup/linkcmds.lpc32xx_mzx_stage_2,
startup/linkcmds.lpc32xx_phycore: Update due to linker command file
changes.
* include/emc.h, include/i2c.h, include/lpc32xx.h, include/nand-mlc.h:
Update for <bsp/utility.h> changes.
* misc/mmu.c: New file.
* Makefile.am: Reflect change above.
* configure.ac, include/bspopts.h.in, include/irq.h,
include/lpc32xx.h, include/mmu.h, misc/emc.c, misc/restart.c,
startup/bspstarthooks.c: Changes throughout.
* make/custom/lpc32xx_mzx_boot_int.cfg,
startup/linkcmds.lpc32xx_mzx_boot_int: Removed files.
* include/boot.h, include/emc.h, include/i2c.h, include/nand-mlc.h,
make/custom/lpc32xx_mzx.cfg, make/custom/lpc32xx_mzx_stage_1.cfg,
make/custom/lpc32xx_mzx_stage_2.cfg, misc/boot.c, misc/emc.c,
misc/i2c.c, misc/nand-mlc.c, misc/nand-mlc-read-blocks.c,
misc/nand-mlc-write-blocks.c, misc/restart.c,
startup/linkcmds.lpc32xx_mzx_stage_2: New files.
* configure.ac, Makefile.am, preinstall.am: Reflect changes above.
* include/bsp.h, include/lpc32xx.h, irq/irq.c, rtc/rtc-config.c,
startup/bspstart.c, startup/bspstarthooks.c,
startup/linkcmds.lpc32xx_phycore: Changes throughout.
* include/lpc32xx.h: Update for utility macro changes.
* configure.ac: Fixed BSP option.
* include/lpc32xx.h, startup/bspstarthooks.c: Added PLL setup.
* make/custom/lpc32xx.inc, make/custom/lpc32xx_mzx_boot_int.cfg,
startup/linkcmds.lpc32xx_mzx_boot_int: New files.
* Makefile.am, configure.ac, preinstall.am, include/bsp.h,
include/bspopts.h.in, include/lpc32xx.h, irq/irq.c,
make/custom/lpc32xx_phycore.cfg, startup/bspstart.c,
