* make/custom/lpc24xx.inc: Flags for EABI tool chain.
* include/lpc17xx.h: New file.
* Makefile.am, preinstall.am: Reflect change above. Update due to API
changes.
* configure.ac, console/console-config.c, include/bsp.h, include/io.h,
include/irq.h, include/lcd.h, include/lpc-clock-config.h,
include/lpc24xx.h, include/start-config.h, irq/irq-dispatch.c,
irq/irq.c, misc/bspidle.c, misc/io.c, misc/lcd.c, misc/restart.c,
misc/system-clocks.c, ssp/ssp.c, startup/bspreset.c,
startup/bspstart.c, startup/bspstarthooks.c,
startup/start-config-emc-dynamic.c, startup/start-config-emc-static.c,
startup/start-config-pinsel.c: Basic support for LPC17XX. New memory
configurations for W9825G2JB75I, IS42S32800B, and SST39VF3201.
* console/console-config.c: Avoid explicit type.
PR 1917/bsps
* Makefile.am, console/console-config.c: Modifications to add dynamic
tables for libchip serial drivers.
* include/start-config.h, make/custom/lpc24xx_plx800_rom_int.cfg,
startup/linkcmds.lpc24xx_plx800_rom_int,
startup/start-config-pinsel.c: New files.
* Makefile.am, configure.ac, preinstall.am: Reflect changes above.
* startup/bspstarthooks.c: Use configuration tables for EMC
initialization.
* irq/irq-dispatch.c: New file.
* irq/irq.c: Moved bsp_interrupt_dispatch() to new file.
* Makefile.am: Reflect change from above.
* include/lpc24xx.h: Added ADC defines.
* make/custom/lpc24xx.inc: Workaround for GCC bug 49641.
* Makefile.am: Fix broken path to cache_.h.
* Makefile.am: Fix broken path to clockdrv_shell.h.
* Makefile.am, preinstall.am: Cache manager changes.
* i2c/i2c-config.c: New file.
* include/lcd.h: Removed EMC definitions.
* misc/dma.c: Fixed initialization.
* include/i2c.h, include/io.h, include/lpc-ethernet-config.h,
include/lpc24xx.h, console/console-config.c, i2c/i2c.c, misc/io.c,
misc/lcd.c, startup/bspstart.c, startup/bspstarthooks.c: New pin
configuration API.
* Makefile.am, preinstall.am: Update.
* README: Add example mkimage command.
* misc/restart.c: New file.
* include/bsp.h: Declare bsp_restart().
* misc/timer.c: Fix typo.
* misc/timer.c: Include <rtems/btimer.h>.
* startup/linkcmds.lpc2362, startup/linkcmds.lpc23xx_tli800,
startup/linkcmds.lpc24xx_ea, startup/linkcmds.lpc24xx_ncs_ram,
startup/linkcmds.lpc24xx_ncs_rom_ext,
startup/linkcmds.lpc24xx_ncs_rom_int: Update due to linker command
file changes.
* include/lcd.h, misc/lcd.c: New files.
* misc/io.c, include/io.h: Documentation, bug fixes, more
configurations.
* include/lpc24xx.h: Added DAC and I2S.
* Makefile.am, bsp_specs, preinstall.am, startup/bspstarthooks.c,
file changes.
* misc/system-clocks.c: Use define instead of function call to allow
smaller delays.
* rtc/rtc-config.c: Fixed type.
* include/lpc24xx.h, misc/system-clocks.c: Removed superfluous include
of <bsp/utility.h>.
* misc/system-clocks.c: Fixed lpc24xx_micro_seconds_delay().
* make/custom/lpc23xx_tli800.cfg, startup/linkcmds.lpc23xx_tli800: New
files.
* Makefile.am, configure.ac: Reflect changes above.
* startup/linkcmds.lpc2362: Typos.
* README: Documentation.
* shared/include/start.h: Define start section attributes.
* include/lpc24xx.h, misc/dma-copy.c, misc/dma.c,
misc/system-clocks.c, ssp/ssp.c, startup/bspstarthooks.c: Removed
superfluous macros.
* Makefile.am, preinstall.am, include/bsp.h, startup/bspstart.c: Use
shared output character implementation.
* make/custom/lpc24xx.inc: Workaround for GCC bug 38644.
* include/irq-config.h: Removed file.
* irq/irq.c: Removed superfluous parameter checks.
* make/custom/lpc24xx.inc: Use VFP floating point model.
